Does anyone know of a TH350 trans mount kit for a 1935 to 1940 Ford frame that still allows the stock wishbones. I don't want to split them, and I'd prefer a bolt in kit. Pictures also always help. Thank you all.
you cant fit a th350 if you dont split the wishbones, you will need to split them if you fit a TH350. the pan is too wide on a th350 not to split them.
like weemark said--you have to split the bones--use a chassis eng. kit--easy to do-- and has mts. for wishbones as well
