Technical 36 Ford rear bones?
Discussion in 'Traditional Hot Rods' started by chaddilac, Dec 19, 2016.
  1. Yep, a quick search will show plenty.
  2. Gary Addcox
    Gary Addcox
    Truer words were never spoken. Take his advice, please.
    26 T Ford RPU likes this.
  3. 117harv
    117harv
  4. Boomchain
    Boomchain
    from Canada
  5. The37Kid
    The37Kid
    Boomchain, Nice, is there a build thread on those bones? The will get copied I'm sure. Bob
  6. BobPer
    BobPer
    Mine coming together.
    117harv and deuceman32 like this.
  7. Harms Way
    Harms Way
    117harv posted a link to a thread I started years ago looking for "Actual proof (not "urban legend"- "a story I herd"or "my best friend's uncle's step father" stories) Actual physical or photographic evidence of failed 35-36 rear bones... Its worth the read......
    https://www.jalopyjournal.com/forum...ctures-of-failed-35-36-rear-wishbones.663784/ If a torque arm makes you feel better... By all means use them.... But I personally have NEVER seen these fail from a torque application.
    As far as setting this rear suspension up... Try to calculate your final pinion angle,.. Only tack weld the axle tube, After total mock up is done and car is under full sprung weight, Check your pinion angle. If it's off just cut the tack weld, adjust the "PA" and weld it up. IMHO
    Here's the last chassis I built with them,.... 392 Hemi, TH-350, 9" Bonco rear with 3:50 Traction lock.. and a 40' Merc front spring.
    F&J likes this.
  8. Harms Way
    Harms Way
    Tom McMullen 35-36 rear bones,..... Under torque
    F&J likes this.
  9. Marty Strode
    Marty Strode
    I'm with you, this car has been on the road for 14 years and 27,000 miles, no bracing and they are wider spread in the front than most applications. Though it does run a skinny rear tire. 100_0427.jpg
    Harms Way and F&J like this.
