Customs 36 Ford Project
Discussion in 'The Hokey Ass Message Board' started by Caddy-O, Sep 8, 2014.
  1. Caddy-O
    Caddy-O
  2. Atwater Mike
    Atwater Mike
    That door gap got 'right in town' with that strap-and-block operation! Nice goin'.
    I've had a few '36es, miss 'em all...
  3. Keep the updates coming.
  4. Caddy-O
    Caddy-O
    Will do... I'm waiting on the frame webbing...so I can get the body back on the frame...
    Things should move a little faster then.
  5. chevy54man
    chevy54man
    from NC
    You sure are doing some great work on her.....outstanding!
  6. Caddy-O
    Caddy-O
    Powerglide adapter for x- member
  7. Caddy-O
    Caddy-O
    Manual rack installed
  8. Caddy-O
    Caddy-O
    The manual valve control valve I'm using.
  9. Caddy-O
    Caddy-O
    Pulling a couple of dents on the tail end
    kidcampbell71 likes this.
  10. TexasSpeed
    TexasSpeed
    from Texas
    Awesomeness.. I need to go back up there to Amarillo and spend a couple weeks hunting for early Fords.
    @JJK - You lied. You said he was going to paint it titty pink with purple flames.
    I'm never listening to you again.
    kiwijeff likes this.
  11. Caddy-O
    Caddy-O
    The steering wheel and column I'm using.... needs some work but I really like the design:
  12. Caddy-O
    Caddy-O
    "JJK - You lied. You said he was going to paint it titty pink with purple flames".
    I have some "Fancy" 22" donk wheels too..... all in keeping with the streetrod motif
  13. alchemy
    alchemy
    You removed the rear crossmember and didn't put anything back in? You might find a lot of twistyness in the frame without something substantial tying the back of the frame together. That small channel at the very rear is not enough. A crossmember that runs near your upper bag mounts and also ties to them would probably be best.
  14. Caddy-O
    Caddy-O
    Yes...I want to test fit my tank before the rear crossmember is fabbed and installed
    WillyKJr likes this.
  15. Caddy-O
    Caddy-O
    Putting the body back on for some test fitting: 015.JPG
  16. Caddy-O
    Caddy-O
  17. TexasSpeed
    TexasSpeed
    from Texas
    Looks good!
  18. Caddy-O
    Caddy-O
    Still need to trim some of the sheet metal out in the trunk area to clear the 4 link and shock mounts.
  19. treb11
    treb11
  20. lewk
    lewk
    from Mt
    Looking really good!
  21. Caddy-O
    Caddy-O
    Thank you all !!
  22. Caddy-O
    Caddy-O
    Engine/ transmission test fit looked good.
    Ready to remove the body, dial it in, and weld in the motor mounts:
  23. Caddy-O
    Caddy-O
  24. JJK
    JJK
    @TexasSpeed Daryl told me once the billet wheels are mounted and the tv monitors installed he would worry about paint.
  25. The body looks real good and you've done some great work. Keep after it! And, it looks like your moving pretty fast too.. Tim
  26. matthew mcglothin
    matthew mcglothin
    Great work Daryl ! Hope to see it at round up! Subscribed!
  27. Nostrebor
    Nostrebor
    Looks solid Daryl. I'm gonna tag along as well.
  28. Caddy-O
    Caddy-O
    Thank you sir.. looking forward to seeing the 51 with the 2 link !
    A friend gave me an original 36 tank a couple of weeks ago, when I opened it up it looked almost new inside.
    So, here we are with the tank and the brake booster mounted:
  29. Caddy-O
    Caddy-O
    006.JPG 010.JPG Pretty productive day.. replaced parts of the rusted subrails that needed repair, got the motor mounts welded in, frame webbing installed, and the body back on the car...
  30. Caddy-O
    Caddy-O
    Right rear fender is pretty bad.
    Someone stick welded a piece of metal flashing over a gaping hole and then filled the area with lead.
    I ended up cutting the whole section out : 001.JPG [/ATTACH] 002.JPG 003.JPG
