I have one of these (or similar), and cannot figure out where they were originally. Also the small VIN? Tag which starts with a "68" 'which I am trying to find the right spot for.
You guys need to do some research and bone up on the location of the Ford Vin numbers. The body number is NOT the Vin nor is there any tag on an early Ford that is the Vin. A 36 Vin will be in between these numbers 18-2,207,111 to 18-3,331,856. For more reference look at this pages. http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm http://www.vanpeltsales.com/FH_web/flathead_serialnumber-patentplate-1.htm
I don't see where I (or J.D. Coop) said anything about a VIN tag being on the car. All we said was that the (2) referenced tags were originally mounted on the firewall. But your comments are correct, their were no VIN numbers back then, only serial numbers.
I took this to mean he thought the small tag was a Vin tag. Then you replied that that was where your tags were and didn't correct/answer his "Vin tag" question. Most hot rodders I know wouldn't be concerned about having those tags much less wondering about correct placement which was the other reason I felt you were both referencing Vin tags
The small tag is a body number, not a VIN (or serial number). The serial number should start with "18", not "68". Feel free to post a picture of what you are asking about. If you are interested in what is correct from a restoration standpoint you should get the book from the Early Ford V8 Club, https://www.earlyfordv8.org/Shop.cfm?id=18&pid=2 I used one of their books when I did my AVATAR, of course taking a few small deviations like the 4 cylinder Mercruiser engine, '39 trans, hydraulic brakes etc. Charlie Stephens
