This frame is from a 1936 Ford; unfortunately the rails are rotten where kick-ups are. The front half is good, rear crossmember is good. These frames fit from 1936 thru 1940 Ford passenger cars, and 1941 Ford pickups. Has the pedal setup from ‘36, and gas tank Cheap because of the rot- a good welder can do anything. The frame numbers are clear, car was last registered in the ‘70s
