Technical 36 Ford flathead backfiring through exhaust WHY??
Discussion in 'Traditional Hot Rods' started by MikeO, Jan 8, 2012.
  1. MikeO
    MikeO
    from MI
    new coil 12volt , carb rebuilt, new wires, valves not sticking,new points and condencer, It had thas problem before all the work and still does it any ideas??
  2. 29pu
    29pu
    Maybe an exhaust leak at the manifold.
  3. could be as simple as crossed plug wires
  4. Slick Willy
    Slick Willy
    Slop in the rotor shaft. Oh and what they said^^
  5. F&J
    F&J
    Put up more symtoms, like when does it backfire...under a load or just sitting there, etc.
  6. Should be able to find the culprit by doing a compression test, a leak down test, and take a vacuum reading. My experience tells me you probably have one of the following problems, a burnt valve, or a broken valve spring.
  7. George/Maine
    George/Maine
    If you could check the plugs and see how burning,I would guess its the middle exhaust seeing it uses same port.Any unburned gas could fire next cylinder to it.
  8. ronnieroadster
    ronnieroadster
    Check the firing order its possible it was wrong befreo replacing the wires and continues to be wrong with the new wires. Flathead Ford firing order is 15486372. Cylinders are numbered as follows front to rear Pass side is 1 2 3 4 driver side 5 6 7 8.
  9. MikeO
    MikeO
    from MI
    Thanks Guys we went through everything and it turned out the new coil was junk too ,put another one on it and it runs great :)
