Customs 36' Dropped axle opinions needed
Discussion in 'The Hokey Ass Message Board' started by tdragger1, Mar 31, 2014.
  1. tdragger1
    tdragger1
    from Az
    Hello-
    I have a stock 36' 5w with nice gum dipped 6.0-16 tires on it. However, I would like to drop it a bit for a nicer stance. It appears most axles are a 4" drop which I think is a bit heavy for these wheels/tires. Has anybody played with this similar configuration? Any suggestions on how far i can go without major clearance issues? thx
  2. A 4" axle won't drop it 4". More like 2"
  3. 36tudordeluxe
    36tudordeluxe
    Maybe just reverse the "eyes" on the spring.
  4. Use. It's a 4" drop axle. It won't lower it 4"
    Try the drop axle first for about 2" then if you need more. ...a reverse eye spring will get you another 1"
  5. tdragger1
    tdragger1
    from Az
    Thanks a lot for the info. guys
  6. Get the original axle dropped to whatever height you wish, cheaper than a new one, real Ford steel and a hell of a lot cooler than aftermarket shit!
  7. jackandeuces
    jackandeuces
    When we drop a 36 axle, it will narrow each side about 1 inch, this will give the needed fender clearance...Aftermarket 4 inch dropped axle is about a 2 inch drop over a stock 36 axle....
