Technical 36 axle with aluminium backing plates
Discussion in 'The Hokey Ass Message Board' started by wood remover, Jan 12, 2019.
  1. wood remover
    wood remover
    Picked up a 36 fromt axle for the wishbone and it has aluminium backing plates ??? 20190107_193010.jpg 20190112_143857.jpg 20190112_144144.jpg 20190112_144150.jpg 20190107_193003.jpg
    catdad49, bct and chryslerfan55 like this.
  2. adam401
    adam401
    Wow that's rad. I've never seen that before
  3. wood remover
    wood remover
    The brake cylinder is also aluminium
  4. Fordors
    Fordors
    Can’t tell for sure but it looks like they were on ‘36 spindles. I imagine they were an early, aftermarket hydraulic conversion that was a direct bolt on.
    gimpyshotrods, Hnstray and flatford39 like this.
  5. adam401
    adam401
    I want those.
    The37Kid likes this.
  6. Was that out of a Right hand drive car or are the photos reversed?
    loudbang and wood remover like this.
  7. wood remover
    wood remover
    Your sharp Wizard !!! Handled the axle a dozen times and never noticed it was right hand drive
  8. Fordors
    Fordors
    Good catch. Interestingly a Google search shows a Norway based bicycle manufacturer named FARA that uses hydraulic disc brakes. Norway was RHD until 1962 when they switched sides. Coincidence, or ???
    gimpyshotrods and flatford39 like this.
  9. Makes those spindles a bit more valuable in the right hands. Now if you only had the steering gear box to go with it.
    The Wizzard
    wood remover likes this.
  10. Hollywood-East
    Hollywood-East
    Seriously Neat pieces!
  11. wood remover
    wood remover
    I will call the guy and see if the box is around, he bought a 40 chassis from another guy and that guy threw the front and rear end under it to roll it around. I bought the front and rear end from him for the wishbone , but had to take everything for , I want it out of my garage price
  12. adam401
    adam401
    Right hand drive round spindles good for push pull steering in an early car without using a steering loop or 34 and earlier square spindles. Interesting.
  13. Curious,, How would that work?
  14. adam401
    adam401
    I dont know. I feel like it would be just like using 34 and earlier left hand drive spindles? Except roundback. Interesting to think about. I've never had a set.
    Pist-n-Broke likes this.
  15. studebakerjoe
    studebakerjoe
    Definitely some cool backing plates.
  16. Those would look great polished ;)
    raven likes this.
  17. You are correct with the exception that you still would need the Bolt on steering loop. Connecting the Drag link as it sounded like you were referring to would not work. No leverage.
    The Wizzard
    adam401 likes this.
  18. adam401
    adam401
    Gotcha. Another look and i see what you're saying.
  19. 1946caddy
    1946caddy
    from washington
    Looks like one has a crack in it but could probably be welded.
  20. Wow. I also found some aluminum backing plates with some early Ford stuff back in 08. Tried to have someone ID them here on the Hamb with no luck. They do look different then yours. Not in very good shape either.
    wood remover and F&J like this.
  21. wood remover
    wood remover
    They are a little different , do you still have them ?? Did you ever have spindles for them ?
    Were they for right hand drive ??
  22. They have to be either after market or later because Henry didn't switch to hydraulic brakes until 1939. If original to that 1936 axle even foreign they would have to be aftermarket.
  23. wood remover
    wood remover
    I believe that they are aftermarket , but from where and who ? I will try a round back spindle in them tomorrow .
  24. I still have them and up to now never saw another set. I didn't get any spindles with these.
  25. familyman!
    familyman!
    Mr. Wood Remover: you have a pair of 1932 license plates listed and told me you would sell them to me. Im unable to get your reply on our conversation thread, so im trying here. Please contact me! Thank you
  26. I've seen some trailer brakes similar to that. I once adapted 12 inch trailer brakes to my '28 Chrysler spindles but they were steel...
