Technical 354 hemi wrist pins???
Discussion in 'The Hokey Ass Message Board' started by junkyardgenius, May 4, 2014.
  1. junkyardgenius
    junkyardgenius
    from Kernow
    Are all wrist pins created equal? I have a set of Venolia forged pistons here but they have no wrist pins. I also have a set of Egge machine wrist pins here that have never been used, would you mix the two or get new ones from Venolia?
  2. mechanic58
    mechanic58
    As long as the dimensions are correct what would it matter?
  3. BOBCRMAN
    BOBCRMAN
    from Holly
    Measure pin length to see if it is compatable with the piston between the circlip length. If O.D. is correct,, use them.
  4. junkyardgenius
    junkyardgenius
    from Kernow
    Thanks guys that's the way I was thinking.
  5. junkyardgenius
    junkyardgenius
    from Kernow
    I measured the pins and they are spot on what I need. Ok so one more question I have measured the pistons and ring grooves and was wondering where to go for the rings? Venolia? Hotheads? Or?
