Technical 351C valve cover
Discussion in 'The Hokey Ass Message Board' started by 26 roadster, Jan 12, 2018.
  1. 26 roadster
    26 roadster
    Deuces likes this.
  2. Deuces
    Deuces
    from Michigan
    Are they stamped steel er cast aluminum...?????:)
  3. kabinenroller
    kabinenroller
    My guess would be a marine engine. I have never seen a factory or aftermarket cover like that. They look low profile so roller rockers probably will not clear them.
  4. gimpyshotrods
    gimpyshotrods
    The bulk-shape is factory style, but the ribs/fins are not.
    Was the 351C-400M used in marine applications? I am not big into things that can easily sink.
  5. 26 roadster
    26 roadster
    Stamped steel
    fbcoach68 likes this.
  6. 26 roadster
    26 roadster
    A friend in Texas gave them to me, said they were Boss 351? He has died on me so no other info available
  7. King ford
    King ford
    from 08302
    Looks like MERCRUISER to me.
  8. Deuces
    Deuces
    from Michigan
    I'll do the search.... Back in a few!!!
  9. Deuces
    Deuces
    from Michigan
    Well, they're not boss covers...
    Maybe the boys from down under (Australia) could help you out....
    Lotz of Ford Cleveland motors down there....
  10. kabinenroller
    kabinenroller
    I doubt very much if they are Boss 351, in fact I am sure they are not. Early Boss cars had stamped valve cover, in ‘70 they went to an aluminum “pentroof” kind of design.
    For something really different Ford offered this from their Motorsport division:
    They are a stud girtel and valve cover in one. The long studs replace the rocker studs and continue to act as a support for the girtel. I have had these for many years and may use them on my Boss 302.
    Deuce-Deano likes this.
  11. RmK57
    RmK57
    Boss 351 covers were aluminum and don't look anything at all like those covers. Boss 302 uses the same ones as the Boss 351.
    Those are still good looking rocker covers. I would strip and repaint them ford blue.
  12. deathrowdave
    deathrowdave
    from NKy
    As stated not a Ford OEM Boss cover , they must be boat stuff , I have tinkered with many Boss engines through out time and never seen these before on the road
  13. john worden
    john worden
    from iowa
    Just a guess. Have I seen them on Big 'Birds with a "Thunderbird" decal on the flat area?
  14. jailbar joe
    jailbar joe
    i'm no expert but i have seen a LOT of cleveland r/c but none like that
  15. 1946caddy
    1946caddy
    from washington
    This is my 351c engine waiting to go into my 35 Ford when I finish a few other projects. Pretty tall valve cover on the bottom side.
    WP_20180113_20_49_22_Pro.jpg WP_20180113_20_49_42_Pro.jpg WP_20180113_20_50_13_Pro.jpg
  16. Dusty roads
    Dusty roads
    Here is my 408 in my F1
    1946caddy, Deuces and loudbang like this.
  17. finn
    finn
    The 69 Boss 302 had stamped chrome covers. Ford switched to the cast covers for the 1970 my, although some late production 69 cars are alleged to have the cast version.
    Crusader Marine (or something like that) converted Ford engines to marine use back then, so that’s another possibility for the source of the covers in question.
  18. 26 roadster
    26 roadster
    Ford blue is boring....
  19. 26 roadster
    26 roadster
  20. kabinenroller
    kabinenroller
    Someone put a brand X alternator on your Boss 302!!!!!
  21. Deuces
    Deuces
    from Michigan
    ...... As long as it works!....:)
  22. 26 roadster
    26 roadster
  23. 26 roadster
    26 roadster
  24. 26 roadster
    26 roadster
    It is a Clevor...
  25. 26 roadster
    26 roadster
    I have searched the internet, Ford,Mercury, marine and after market. I am unable to identify them.
    They are just different.
  26. LM14
    LM14
    from Iowa
    Look a lot less me some Trans Daly offered several years ago.
    SPark
    26 roadster likes this.
