Technical 351 Water pump
Discussion in 'The Hokey Ass Message Board' started by Boneyard51, Mar 21, 2019.
  1. Boneyard51
    Boneyard51
    I need a water pump for a 351 Windsor that has the intake on the passenger side. Wondering if anybody knows of one? Thanks in advance.
    Bones
  2. Last edited: Mar 21, 2019
    Boneyard51 likes this.
  3. Boneyard51
    Boneyard51
    Thanks, Steve! Here’s our engine.
    Bones
  4. One thing I should have noted; up to '69, Ford used the three bolt lower pulley, then switched to the four bolt in '70 (which is when the passenger-side inlet disappeared for good). This is where guys get into trouble with the 'why don't the damn pulleys line up?' issue. It can be done, but can take some time to get the right combo...
  5. Relic Stew
    Relic Stew
    from Wisconsin
    3 bolt and 4 bolt dampers were made so the timing marks match the location of the pointer, which is opposite side from the pump inlet. 3 bolt for passenger inlet, 4 bolt for driver inlet.
    Also, the Bronco used the passenger inlet pump through '77, as the steering box interfered with a driver side radiator connection.
  6. LM14
    LM14
    from Iowa
    I use Pro Products balancers because they have 3 and 4 bolt patterns on every balancer. Also walked into a local parts store and asked for a '69 Galaxie pump and they had one in stock. Lets you use Chevy radiators!
    SPark
    MO_JUNK and Boneyard51 like this.
  7. seb fontana
    seb fontana
    from ct
    Not to side tract but what is header application?
  8. Boneyard51
    Boneyard51
    Corvair???
    Not real sure what exact race car, but a circle track car. A friend gave them to us to start the engine, we have another set for our B-mod circle track car.
    Bones
