351 Cleveland questions
Discussion in 'The Hokey Ass Message Board' started by hotrodwelder, Mar 8, 2009.
  1. hotrodwelder
    hotrodwelder
    Here's my question; I have a mild 351C it doesnt see many rev's above 3-3500rpm, it's a streetable enginew/mild cam.
    What i'm getting is; it seems to blow a lot of oil out of the valve cover breathers, it has a PCV valve and everything is clean- no plugged hoses or lines, but this thing will oil my firewall and vave covers and makes a hell of a mess. It's a fresh motor w/ about 4k miles on it and it's getting old cleaning up after it. BTW the valve covers have baffles in them before and aft the vent holes.
    This is a question all my ford buddies can't answer.
    Could I get some ideas here, and no I'm not pulling it and putting in a Chevy!
  2. hotrod-Linkin
    hotrod-Linkin
    broken ring or busted piston...time for a compression check
  3. X2...although I'd suspect rings that never sealed correctly.
  4. This is not a Ford question it is an engine question in general.
    This engine has a broken piston / rings.
    Do a compression test and find your dead hole.
  5. R A Wrench
    R A Wrench
    from Denver, Co
    Agreed! Do a comp check, you are showing blow by. I have been running a 351C for many years with no problem.
  6. hotrodwelder
    hotrodwelder
    I will give it a comp check and see what's up. Thanks!!!!!!
  7. Play400
    Play400
    How much compression, distributor advance and what do you run for fuel? Thing ever ping? Only time I blew oil thru the breather was when I broke a ring land because of ping, the soft spring in the dizzy was dropping and holding the mechanical advance open at times. Found the problem when the second know good engine started to ping and the only thing we reused from the old set-up was the distributor. BTW a compression check did not highlight this problem as the piece seemed to fall back into place when testing.
  8. atlantic62
    atlantic62
    Are you running synthetic oil ? Can't break an engine in on synthetic.does it smoke out the back too?
  9. hotrodwelder
    hotrodwelder
    The Dist is a Mallory unilite w/ vacuum advance. 8.5:1 compression. Never ran synthetic oil and it doesnt smoke.
    My guess is the rings havent seated yet. My informants told me about ZDDP- zinc in the oil. This engine has a zinc additive in the oil, but maybe when it was in break-in period the oil was low on zinc, I dunno??
    Did I mention the oil comes from both sides of the engine.
    Thanks for the input guys..
  10. krooser
    krooser
    The zinc wouldn't have any effect on ring seating... and many new cars use synthetiv oil as a factory fill these days.
  11. Play400
    Play400
    I had a 351M and during the winter if the PVC became restrictive it almost immediately blow out the rear seal. Couldn't be something as simple as the PVC hose collapsing and then having the crankcase pressure and oil taking the easiest way out when back pedaling.
