Here is a 350 Chevy Engine that spent the majority of its life in a '39 Chevy Coupe. It was replaced for an aluminum head 383. Here's the skinny: New Cam and Lifters New Timing Chain Set New Weiand Aluminum Intake New Flex plate Aluminum Pulleys and Short Water Pump Accel ignition and wires 600 CFM Holley Carb (carb works as seen in the video, however, will need gaskets from sitting) Engine has 60# of Oil Pressure and pulls 22 inches of vacuum. I would estimate the engine to make roughly 300 HP. Casting number 3970014 with 882 Heads. Comes complete with the starter & flex plate. The partial VIN on the engine is completely visible and intact for those who are in states which require that information. Engine will be sold with the appropriate Bill of Sale. I will ship the engine to a business with a standard height dock for an additional charge. Please inquire for pricing and availability. Click HERE to see the engine running. Vern 563-542-3137 Vern 563-542-3137
BTTT I've been checking shipping. It's around $150.00 from Dubquue, IA to a dock in Ohio or TN. Should be similar elsewhere.
