Featured Projects 350 Chevy or 351w into a 50 merc coupe?
Discussion in 'The Hokey Ass Message Board' started by Sickboys50, Sep 19, 2022.
  1. 350 chevy
    78 vote(s)
    61.9%
  2. 351 Windsor or Cleveland
    48 vote(s)
    38.1%
  1. Rex_A_Lott
    Rex_A_Lott
    Do you HAVE to swap the motor? Or is this something you just want to do? The old flatties are fun to tinker with too, and can be reliable too. At any rate, if its a V8 when you yank it, dont scrap it, somebody's gonna want the crank if nothing else. You find the right person and you might be able to swap it for a running SBC. Good Luck
    Sickboys50 likes this.
  2. A Boner
    A Boner
    Put the Ford engine in…you might get an award for putting a Ford in a Ford, to compensate for the hassle you will go through for making that choice… (it fit)!
  3. flatout51
    flatout51
    Junk yard 351w with a dingleball rebuild and be done. AOD out of the same truck and you're set.
  4. nochop
    nochop
    from norcal
    Depends on your skill set. Either way it’s a challenge, you feel lucky?
  5. Mr48chev
    Honest no BS question. Do you rabid Ford in a Ford guys ever actually put later model Small blocks in early 50's Ford (not truck) chassis without major suspension changes?
    I see the put a 351 in it but have you ever actually had a 351 hanging off a chain hoist trying to install it in anything?
    People toss around the Brono pan but that isn't a lot of help with a Merc or shoebox. The front still drops down a lot to clear the oil pump and you can't cut and fit the pan to fit the crossmember.
    When you look at the stock Merc frame with or without the flathead in it and see where the front if the engine sits, Guess what? The fuel pump and oil filter are right in the big middle of the crossmember of the Merc even if you spend a bunch of money on a pan. For the guy building on a budget the Ford engine isn't practical to keep the budget under conrol. 351 Cleveland.jpg Ford-351-Windsor-3.jpg Rear sump bronco pan.jpg Doctor-Detroits-1951-Mercury-Eight-Build-Before-and-After-3-1024x370.jpg
  6. Rand Man
    Rand Man
    I voted for Ford, but changed my mind. I agree with keeping it simple. Do your research and set an achievable goal. I’m the king of unfinished projects, so verily, verily I say unto you; understand your constraints in time, money and wherewithal. Make that happen.
    What is your budget? You could spend a couple thousand getting that flatty running. Ask me how I know.
    Sickboys50 and ekimneirbo like this.
  7. MeanGene427
    MeanGene427
    from Napa
    An electric fuel pump and a remote oil filter are quite simple, and there are other oil pans to consider- the mid-sump 4x4 pans were designed to help keep oil at the pickup at different angles, not for crossmember clearance. A 289/302 also is easier dimensionally than a 351. The 351 has larger main bearings/ caps, and the pan grew with it. Rabid? Really? One can put almost anything in anything with a little ingenuity, you don't have to settle for an el cheapo and boring scrub engine- it's called hot rodding
    warbird1, RmK57 and flatout51 like this.
  8. flatout51
    flatout51
    Simple. I had a 289 in my 49 with stock suspension before switching to Mustang II. The foxbody swap pans for 351 are cheap and easily obtained from any of the big box stores. Shoebox central sells the motor mount kit that comes with a trans mount as well. All the SBC guys are soooo scared of the Ford and it makes zero sense.
  9. Budget36
    Budget36
    And here I thought hotrodding, especially in a traditional view, was about performing better with the least amount of effort and dollars.
    Or is it make a lot of effort, spend more $$?
  10. flatout51
    flatout51
    The argument over price to run a Ford compared to Chevy is antiquated. The aftermarket for Ford has exploded since the early 90s and the prices are virtually the same. Just sounds like laziness to me.
    Sickboys50 and warbird1 like this.
  11. MeanGene427
    MeanGene427
    from Napa
    Yep, I firmly believe that most (NOT all) of the "Put a Chebbie in it" crowers have just never done it any other way, and many (NOT all) are way dependant on the Speedway method of "hot rodding". There is a big difference between cheap and inexpensive lol...
  12. Budget36
    Budget36
    Ya think. Okay. Off to the Google thing, oh, who makes a kit to put the 351 and trans in his car?
  13. A Boner
    A Boner
    Glad you added…(NOT ALL)!
  14. flatout51
    flatout51
  15. MeanGene427
    MeanGene427
    from Napa
    How about the guy doing the work lol... Things can be done without a "kit". A tape measure is a good start...
    Google- creating instant experts since 1998!
    73RR, Sickboys50 and flynbrian48 like this.
  16. Budget36
    Budget36
  17. Budget36
    Budget36
    You funny, now everyone funny too.
    You did read the original post, right? I think you’re pretty intelligent so I’ll leave it at that.
    I will just say “first project”.
    Edit: It was in post 10
  18. MeanGene427
    MeanGene427
    from Napa
  19. MeanGene427
    MeanGene427
    from Napa
    You're welcome- and you get it lol :D
  20. And ya can hook either one to the stock manual trans
    My kid loved driving my 3 on the tree
    I’ve got an old merc parts beater with an SBF.
    I’ll try the get some pics posted for ya.
  21. MeanGene427
    MeanGene427
    from Napa
    My kid has a very sweet 49 F1- when he got it, it had been unnecessarily bastardized with a scrub engine. The orange lump was quickly on the ground. It now has a supercharged 302 and runs very, very well and is INTERESTING lol
    Sickboys50, RmK57 and Rand Man like this.
  22. aussie57wag
    aussie57wag
    from australia
    Yes. That does not mean he would of used a sbc had it been available.
  23. 327Eric
    327Eric
    from Diablo Ca.
    Go with a sbc, just easier all around to get parts for, especially starting from scratch.
  24. twenty8
    twenty8
    And here we are, doing this same old dance again.......o_O
    Here are the facts regarding the use of SBC engines in early Ford hot rods.
    1). The Ford Y-block was introduced in 1954, and the SBC a year later in 1955, so availability is not a major factor.
    2). The SBC engine was an easier swap into the early Fords because of it being shorter. This is a major factor.
    3). The easier installation kept the cost of the swap down, and made it a more attractive option for hot rodders.
    4). Because it was done a lot more often, the SBC swap became what we now call "traditional".
    The argument over which engine is "better" is pointless and irrelevant. If we are wanting to build in a manner that parallels the pre-'65 era, using a SBC engine definitely fits (pun intended). It is not about Ford versus Chevrolet. It is more about the way it was, and that should be all that matters.......:rolleyes:
    My thoughts???
    Do your homework, and use the engine that best suits your skill level, your budget, your passion, and your final vision. Do now what you will still be happy with in 10 years time. It is always more cost effective to do it once and then just enjoy it.....;)
  25. flatout51
    flatout51
    Less than $100 difference. The price argument is done. It's all personal preference.
    Sickboys50, warbird1 and Budget36 like this.
  26. flatout51
    flatout51
    This is just pure ignorance. Small Block Ford is just as easy to get parts for as a SBC.
  27. flatout51
    flatout51
    Next thing people will be talking guys out of chopping their car because it's harder than leaving it stock... "it will be harder to find glass!"
  28. Here’s a 49 merc with a SBF in my bone yard.
    Crude but era friendly :)
    filter is tight. But that’s an easy issue to handle.
    front sump pan. Sits at a bad angle. Rear sump pan would drop it a lot.
    C9B925EE-D572-48CE-A3EA-E5BACD9DFFEA.jpeg BFE74F56-6397-4979-BCE2-B623C5748D0F.jpeg
    Has a good bit of room above the drag link
    Sickboys50 and flatout51 like this.
  29. Truckedup
    Truckedup
    Silly boys ,if you are running points the best engine is the one with a front mounted distributor..:D
    Sickboys50, Cooon and flatout51 like this.
