35 Ford stock suspention?
Discussion in 'The Hokey Ass Message Board' started by Langan, Jan 29, 2007.
  1. Langan
    Langan
    Want to know what you think.
    I have some left over parts enough to make a 35 Ford Truck. Question is Split bones,4" drop axel, reversed spring, front. Stock reversed spring, split stock reinforsed bones, 9" ford with coil overs for fine tuning, maybe raise the spring mount for ride hight, in the rear.
    Will it ride OK or am I wasting my time
  2. It should ride fine. There are thousands of rods out there running an identical setup.
  3. Langan
    Langan
    Thank
    All I see are Pinto front and rear leave
  4. HeyMang
    HeyMang
    It will be way cool and very comfy down the road. Just ditch the mechanical brakes up front (but im sure you know that already).
  5. Langan
    Langan
    Does anyone know were to or how much to move the rear spring mount up? I want to 2" clearance between frame and axl then C notch the frame. The reverce spring is said to lower it 2.5"
