35 Chevy coupe
Discussion in 'The Hokey Ass Message Board' started by Joseph Allen, Jun 11, 2017.
  1. Joseph Allen
    Joseph Allen
    Looking for options for what rear end to use on my 35 Chevy coupe standard, and help or (options ) would be very helpful, thanks[​IMG]
  2. Chuck Craig
    Chuck Craig
    from Ocala FL
    TFoch and Joseph Allen like this.
  3. Joseph Allen
    Joseph Allen
    TFoch likes this.
  4. Joseph Allen
    Joseph Allen
  5. dorf
    dorf
    from ohio
    s10 is very narrow just cleared the springs on my 35 master .so i had custom rims made ,looked pro streeted
    Joseph Allen likes this.
  6. 55-63 chevy rears are traditional.
    what front end are you changing to?
    Dooley, 3banjos and Joseph Allen like this.
  7. mgtstumpy
    mgtstumpy
  8. I used a 10 bolt out of a two wheel drive Chevy S10 with a Posie rear leaf spring kit in my 33 Chevy. Work well.
  9. Joseph Allen
    Joseph Allen
    Mustang 2 front
  10. eberhama
    eberhama
    S10 4x4 rears are wider than 4x2s, ZR2 4x4s are wider still (and 8.5") you'll find whatever width you decide on, one out of a blazer will be cheaper and easier to find than a pickup one.
  11. Joseph Allen
    Joseph Allen
  12. Joseph Allen
    Joseph Allen
    So I'm getting ready to order and have built a ford nine inch rear end for my 35 Chevy coupe, I believe 50 1/2 inter flange to flange is close to correct width, but don't want to make a mistake, any input on how to measure this ?
  13. My 10 bolt Chevy rear in my 33 Chevy master is 54 inches from wheel mounting surface to wheel mounting surface.
    tb33anda3rd and Joseph Allen like this.
  14. Joseph Allen
    Joseph Allen
    What did your rear end come out of if you do t mind me asking ?
  15. Joseph Allen
    Joseph Allen
    Opps never mind , I see it on this post
  16. It was important to me to keep my drive train all Chevy.
    Joseph Allen, Fern 54 and tb33anda3rd like this.
  17. Joseph Allen
    Joseph Allen
    Yes I can understand that , do think it could handle the tork of 364 nailhead with around 400 horse
  18. primed34
    primed34
    S10 rears are stronger than you might think. The 4.3 v6 was pretty peppy little engine in the late 80's and early 90's. I've got a S10 under my '34 Chevy coupe. I've also had two S10s with 4.3s.
  19. I've got a 2000 4X4 S10 under my 36 standard fits great... may be some pics of it in my build thread... just had to grind off the old spring perches and weld on new ones in the correct location
  20. Joseph Allen
    Joseph Allen
    Well shoot ! Maybe I shouldn't go and spend 3 grand on a ford 9 then , thanks for input
  21. The S10s had a rear end with 7.625" ring gear and another with 8.5" ring gear. The codes in the glove box for the gear ratios are GU4 - 3.08, GU5 - 3.23, GU6 - 3.42, GT4 - 3.73, GT5 - 4.10 and HC4 - 4.56
    tb33anda3rd likes this.
  22. Joseph Allen
    Joseph Allen
    Sweet! much gratitude, that all I need to know, except some had disc breaks right? Do you know what year?
  23. Yes some had disc but not sure what years. Believe it or not I got a lot of info searching on ebay. I bought mine local though because I got a better deal. Hope you find what you need.
    Tom
  24. Joseph Allen
    Joseph Allen
    Thanks again for the input! Found a rear end in Idaho with 8.5 , and 373 's disc brakes
    TFoch likes this.
  25. 6inarow
    6inarow
    5 lug or 6 lug?
