I just recently purchased a 35 Ford Pickup, complete body & chassis. It is titled a 35 and vin matches the stamping on the truck. Here's the challenge, the A pillars are smooth and flow like a 36. Its suppose to be an original cab, doors and sheet metal. The hood is def 35 and no garnish moldings in doors. My biggest question is there a such thing as a very late 35 that had smooth A pillars? I know that parts were used till they were gone, and Henrys reputation for being savvy with his usefulness, but it doesn't make sense to me to take a 36 style cab then use all 35 parts and sell it as a 35. You would think it would be sold as a 36 with the left over parts. This truck is pretty well documented with only 2 previous owners. The last owner had it in storage for the past 45 years. Any insight would be great!
Check your Id number against this site. http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm That way you know least what year the ID number is. You can go from there.
The F-100 designation did not appear until 1953.....it's just a plain old pickup. If the title says '35, then I would call it a '35......JMO
True indeed what RMR&C said, Ford didn't start using F-100 until 53, in 48 is when the 1st F Series trucks were started. So anything prior to 48 is just considered a Pickup. As far as the pillars, it very well could be a late build of 35, Ford did seem to use up all of old stock so it could of ending up with a 36 Cab but if vins still match up, I'd keep stating it as a 35.
Wow, cool link on the serial #s. My # indeed is a very late one 18-2,203....... and the model year 35 ending at 18-2,207...... It is a true 35, so I guess that means the smooth A-pillar application started in late 35 model year.
