348 Starter question
Discussion in 'The Hokey Ass Message Board' started by dolsen37, Apr 20, 2013.
  1. dolsen37
    dolsen37
    from Nebraska
    I have a 1961 348 Chevy with a small block aluminum bell housing bolted between the 348 and W/C-S10 5 speed. Will a small block Chevy starter bolt up the the 348 block? Does anybody know what year starter I should buy to bolt up to the 348? If I can't figure this out I will buy a 348 bell housing and pull it all back apart and start over. I inherited this set up when I traded for the car.
    Thanks again HAMB
    Dan
  2. krylon32
    krylon32
    from Nebraska
    1. Central Nebraska H.A.M.B.
    I used an aftermarket scatter shield type steel bellhousing on a deuce pkg car I did for a customer and used a Power Master gear reduction starter. If I remember you have to use the staggered bolt pattern? Can't remember if I used the large or small flywheel????
  3. black 62
    black 62
    from arkansas
    used to be trick to use a w motor starter on a high compression sbc ---had to change the nose...
