I am planning on putting a 348 in my 51 Chevy its a 58 engine, I have a small block in there now, can I use the same mounts, and will a TH350 bolt up to it and what converter do I use? any help would be great! I am pretty sure the mounts are the same! John
Check the clearance between the oil pan and the steering center link.Not sure of the setup on a 51 but I had to cut my oil pan for clearance when putting a 348 in a 56 Chevy.
You will be fine John, other than the sixpack, enlarged pecs and virility a W Motor brings to the equation!
Should be fine. There are issues with the starters(bolt placement) and I forget teh ring gear size. Our social group should help, if not, www.348-409.com has a good tech section
