Projects 34 ford 3 window built from 2 door sedan
Discussion in 'Traditional Hot Rods' started by blindowl, Dec 31, 2017.
  1. 51box
    51box
    from MA
    Nice work, can’t wait to see this come together
  2. 3blapcam
    3blapcam
    from Austin, TX
    Jim... did you finish that build? I started watching that thread a long time ago...
    Nailhead A-V8 and loudbang like this.
  3. mike bowling
    mike bowling
    If Smitty says so, I'd take it to the bank!
  4. blindowl
    blindowl
    from MASS
    I love it , great job.
  5. blindowl
    blindowl
    from MASS
    Starting the floor for a nice base. Floor needs a lot of love , got a sheet of 4x8 16g on its way to fix the edges and a few other spots.
    Im gas welding this whole car . Having a lot of fun
  6. mike bowling
    mike bowling
    I got a demonstration the other day at the "Recovery Center"- this method of welding is pretty impressive. This car is gonna be something...........
    Lookin' good, Brother!
    wheeldog57 and loudbang like this.
  7. sloppy jalopies
    sloppy jalopies
    Don't break the piggy bank yet, memory has been telling me that townie used the '35-'36 truck posts on a '32 - 3 window... not '33-'34 coupes...
  8. blindowl
    blindowl
    from MASS
    Little bit of progress. Waiting fot the quarter panels to arrive before I cut or weld anything
    Placed the 1935 ford trunk back sedan rear roof over the doors. Lots of work needed to the belt line area. Lots of metal to work with
  9. JimSibley
    JimSibley
    Mine is all cast off junk from 33-4 sedan stuff. A little 4 door junk mixed with some Tudor doors and the rear quarters are made from a set of sedan fenders and home made body line section.
    48fordnut and loudbang like this.
  10. blindowl
    blindowl
    from MASS
    Way too humpy
  11. blindowl
    blindowl
    from MASS
    Other side.
  12. you're right it looks almost '32ish...the 2 dr is too bulbous and straight the '35 section has the correct angle and profile but its so tall from the beltline to the top and the body bead is different.... looks like if you cut the body bead out of the 2 dr. roof sections and welded them further up the '35 roof panel you'd be pretty close.
    ?...did you find the pass. side?
    Which rear window is closest in size and shape to the 3W?
  13. blindowl
    blindowl
    from MASS
    Im just messing around now. Theres going to be tons of slice and dice.
    I'll use the 2dr belt line then blend it into the 35 belt line/top. Its going to be a radical chop
  14. blindowl
    blindowl
    from MASS
    This is pretty bulbous too. Im using it as a pattern
  15. 34ford5w
    34ford5w
    from Colorado
    Wish you guys were closer o could hook you up! I have a couple pairs of quarters 1 original 3w pair and a set of Don Smarts plus 5w perfect for these projects! Go man go!!!
    Sent from my SM-G930V using The H.A.M.B. mobile app
  16. 34ford5w
    34ford5w
    from Colorado
  17. mike bowling
    mike bowling
    Time for pie cuts on those corners ? ( or go to Colorado!)
    You can do it!
  18. 34ford5w
    34ford5w
    from Colorado
    Lol!! They're up for grabs I don't need them! They were extras and cut offs! I use a lot of SAR parts. 5w got new SAR and 3w got new SAR and I bought Those Don Smarts awhile ago! PM me. I still want to try my hand at a 5w from 4dr I have the parts as well. I also have a 2dr back half up for grabs!!!!
  19. sloppy jalopies
    sloppy jalopies
    ROAD TRIP ! they say its white this time of year...
  20. 34ford5w
    34ford5w
    from Colorado
  21. 34ford5w
    34ford5w
    from Colorado
  22. loudbang likes this.
  23. blindowl
    blindowl
    from MASS
    Im real interested in those 3 window quarters.
  24. SD55-1
    SD55-1
    Very cool
  25. ^^^^that's a scam. My friend just sold that car a couple months ago.
  26. blindowl
    blindowl
    from MASS
    A little messing around
  27. wheeldog57
    wheeldog57
  28. blindowl
    blindowl
    from MASS
    Basically building the car around the chopped doors. I really need to finish the floor and buy subrails before I move forward with anything. Time and $ which I dont have haha
    Doctorterry likes this.
  29. zzford
    zzford
    You should have restored it. It was too nice to cut up!!! :)
