Technical 331 Hemi RPM question
Discussion in 'Traditional Hot Rods' started by sdimpala64, Nov 29, 2018.
  1. sdimpala64
    sdimpala64
    from SD CA
    Trying to decide what gear to run behind a stock 331 Chrysler Hemi in a Model A with automatic transmission.
    Tire height will be 31.5 inches, Calculations at 75 mph:
    Gear RPM
    2.75 2259
    3.00 2464
    3.25 2670
    3.5 2875
    Will spend a good amount of time on the highway.
    Any recommendations are greatly appreciated. Thanks.
    loudbang and Bandit Billy like this.
  2. Some info on the engine specs would be helpful, but if highway running was my main concern, I would be going for the 2.75 gear set. A properly built 331 will have plenty of torque down low to get a light weight Model A moving with that tall of a rear gear.
  3. My 32 has 3.48s with 31.5s and no overdrive. Different engine, but still a small V8. I like the combo. Its not too buzzy while giving enough gear to move well with only 300 (if that!!) or so HP.
  4. town sedan
    town sedan
    Slush box, or stick shift? It will make a difference in how the car drives. I'd stay in the 3.25:1 to the 3.50:1 range with a stick shift.
    -Dave
  5. sdimpala64
    sdimpala64
    from SD CA
    FrozenMerc: Completely stock rebuild is what I was told.
    town sedan: automatic transmission(no overdrive)
    loudbang and town sedan like this.
  6. foolthrottle
    foolthrottle
    the higher ratio worked for me for long distance 75 plus speeds something like 3000 RPM the early hemis don't like the higher revs. mine was a 331 hemi 750 cfm carb, GM ignition, th400, GM 12 bolt posi 2:90 with that set up I could buzz up over 120 without going over 4500 RPM
  7. Bandit Billy
    Bandit Billy
    I am building a 330 Hemi for my truck. I already had built the 9 inch posi with 3:70 gears. In-between is a A518 overdrive automatic. If I was not running an OD I would not have exceeded 3:55. If it helps.
    loudbang and 73RR like this.
  8. DOCTOR SATAN
    DOCTOR SATAN
    from okc
    Quickie solves all your worries, holler if ya need one.
  9. 73RR
    73RR
    For extended highway use I'd keep the rpm below 3000, not beause the engine won't tolerate more, but just because of the inherent noise generated.
  10. foolthrottle
    foolthrottle
    this is the engine running in neutral
    Rick28 likes this.
  11. sdimpala64
    sdimpala64
    from SD CA
    Thanks to all who responded.
  12. Brand Apart
    Brand Apart
    from Roswell GA
    I agree with 73RR. (Pretty much always)
    Side note. I'm doing a 354 and hoping to be cursing at 75 at approx 2300, but am quite a bit away from testing it out.
  13. sdimpala64
    sdimpala64
    from SD CA
    After talking with 73RR I have chosen to go with 3.25 gears. Thanks again
    to all the members that responded.
  14. George
    George
    OEM with the OEM 2 speed tranny was 3.36.
