Projects 331 Cadillac V8 extra grrrrunt
Discussion in 'The Hokey Ass Message Board' started by 49CadiClubCoupe, Sep 8, 2010.
  1. Hi Hamber's
    Looking for some been there done that tips for wringing some extra power out of a 331 Cadillac V8. I am about to start a full resto of a '49 Caddy and although I want to keep it as close to original as possible in most areas, I am looking at some suggestions for tweaking the 331.
    From what I have seen, there is not a huge amount to do. I am definitely not interested in dropping in a 350 crate, I want old school and a modest increase on the standard 160HP.
    Seen some nice dual carb set ups and read about some dizzy changes and cam grinds. Any other suggestions?
    Cheers
  2. 31modelo
    31modelo
    Higher comp pistons and some later 331 heads will help. Down fall of later heads you lose the center bolt valve covers.
  3. M.Edell
    M.Edell
    read my old Tech Post in the Tech Archive, its under my old name "Cadillacin Marcus"
  4. steel rebel
    steel rebel
    Just get some later heads and a four barrel carb. and manifold and you will vastly improve the H.P. on that '49 engine.
  5. falconsprint63
    falconsprint63
    from Mayberry
    see Mr Edell's post. 390 heads are a great addition.
  6. M.Edell
    M.Edell
    Indeed! Chevy Valves even Better!
  7. KrisKustomPaint
    KrisKustomPaint
    A 6-71 will put a bit of pep in your step. It'll fit under the hood of a 49. It'll look stock on the out side and you can always take it off if it scares ya.
  8. johnny bondo
    johnny bondo
    from illinois
    change the transmission to a manual too if its not already that.
  9. Thanks all for your tips,..maybe not so much for KrisKustomPaint and the 6-71 tip! :)
    Sounds like there are a few easy options there, nice. Sounds like they way to go.
    Thanks again
    Cheers
  10. 73RR
    73RR
    As suggested, a fresh regrind on the cam can add a bunch of power but don't go too big unless you also bump the compression. And, with any regrind, you will need either adjustable rockers or adjustable pushrods.
    If you need help with the cam or pushrods just send a note.
  11. _charles_
    _charles_
    from Tampa, Fl
  12. KrisKustomPaint
    KrisKustomPaint
    I was just razzin' ya a bit chief. But seriously 6-71, it could be cool.
  13. mart3406
    mart3406
    from Canada
    If you want to keep it 'period correct'
    and not go so crazy with mods as to
    effect normal drivability, maybe look
    for a Paxton or McCullough supercharger
    for it. Back in the early and mid-50's
    Paxton/McCullough offered bolt-on
    supercharger kits for most cars of the
    day, including Cadillacs. If you can find
    one of the more common factory units
    for a Ford, Studebaker or even a Kaiser
    and could fabricate your own mounting
    brackets and pulley assembly etc., you
    could probably recreate (or do a pretty
    reasonable facsimile at least) of the
    aftermarket kit they offered for the
    Cadillac V8. Since in *stock form*, they
    only put out about 5 or 6 lbs. boost it
    would still be compatible with the stock
    compression cast pistons - but that's still
    enough boost to give solid 40% horsepower
    increase over stock.
    Mart3406
  14. Thanks all, and no worries Kris I knew you were stirring and I had a chuckle about it. Would definitely be cool!
    Thanks Mart - I didnt know about the Paxtons in that era - thought they were more a 60's Mustang thing but very interesting. I do like a blower, however for the '49 think nothing would be cooler than a set of carbs on a dual or tripple manifold. (Thanks in part after seeing them on your site Charles!) I found both your sites looking for info on Caddies and dual carb set ups. I was looking for the buy it now tab on a few of them!!!!
    Thanks 73rr I did read that about the grind/resulting potential probs. Dont plan on going too crazy.
    I am thinking a cam grind and some 390 heads with a twin or tripple carb set up like on the '58 era Chevs
  15. just got my 1949 331 back from the builder.... wasnt cheap to build.. but well worth it ... i hope..
    ls1yj likes this.
  16. KrisKustomPaint
    KrisKustomPaint
    Hey pocket what intake is that?
  17. Verry very nice pocket - hope it works out well
  18. FSHTNK
    FSHTNK
    On your website, you say "Basically a 390 is a bored out 331 and 390′s can’t be bored out that far."
    Does this mean my 331 (or any) may take a 4" bore?
