Projects 33 Ford 5 window coupe build - 50's style
Discussion in 'Traditional Hot Rods' started by ss34coupe, Feb 3, 2008.
  1. ss34coupe
    ss34coupe
    That chopped 32 grill looks good! Mine was done by someone in the 60's, and the insert was cut and brazed back together. Not perfect by any means, but I don't plan to change a thing, I like it the way it is.
  2. ss34coupe
    ss34coupe
    John has been busy working on the wiring - we now have turn signals and brake lights, all working perfectly. Used an old turn signal switch that mounts on the steering column, a piece given to me many years ago by my friend the late Gene Williams, another 34 Ford guy. IMG_2364.jpg
    duncan and loudbang like this.
  3. ss34coupe
    ss34coupe
  4. ss34coupe
    ss34coupe
    Old Stewart Warner gauges are being used. Still looking for a SW speedometer, but we will use another brand until a SW is found. IMG_2365.jpg
    48fordnut, brEad and loudbang like this.
  5. ss34coupe
    ss34coupe
    John has been getting more done on the coupe - connected the gas line to the tank, installed the throttle pedal and linkage, got the brakes working, done most of the wiring, and on and on it goes. Should be a running hot rod soon! IMG_2487.jpg IMG_2491.jpg
  6. Scott Mize
    Scott Mize
    What did the finned brake drum come off of?
  7. triumph 1
    triumph 1
    They look like 45 fin Buick drums to me.
  8. ss34coupe
    ss34coupe
    Yes, they are 45 fin Buick drums on Lincoln brakes.
  9. duncan
    duncan
    Really coming along Steve. Good work John
  10. Chevbucket
    Chevbucket
    The coupe left me today back to Steve's house. Still lots of work to do. :) 100_5149.JPG
    brEad, loudbang and ss34coupe like this.
  11. touring20
    touring20
    Dang that thing is just bitchin ! What you Have there is a very convincing time capsule,
    Built now !
  12. ss34coupe
    ss34coupe
    yes, John has done some great work on the coupe. He will continue to work on it at my place as we push to get this build finished. More updates soon, today we are experiencing an unusual feature for us in this part of the world - winter!
  13. Yo Steve! Keep strokin, brotha...I finally got mine on the road...drove it to the HAMB drags last summer. What fun!!!!
    ss34coupe, exterminator and loudbang like this.
  14. ss34coupe
    ss34coupe
    Thanks, Rocky. It's time to get my coupe finished - started collecting parts for the build in 2001! Should be soon, thanks to John's help with wiring and other jobs.
  15. Duke
    Duke
    Did you get the gauge in?
  16. ss34coupe
    ss34coupe
    Dustin - no, we used another speedo. It was already here before yours arrived. May switch later but for now I just want to get everything working.
  17. ss34coupe
    ss34coupe
    IMG_2606.jpg More progress on the coupe. Wanted to raise the rear a bit to get better clearance for the tires. Hamber Duncan milled a half inch steel plate and it was placed between the 40 Ford rear spring and the stock 33 Ford crossmember. The crossmember had been modified so the 40 spring would fit. Now the stance is right where I want it! Thanks, Ron! IMG_2609.jpg
    brEad, loudbang, ls1yj and 3 others like this.
  18. ss34coupe
    ss34coupe
    The 4 inch chopped 32 grill shell is finally bolted in place. Got it years ago, originally off a Model A hot rod built in the 50's or 60's. Imperfect as it is, some of the work done with brazing, it is perfect to me. IMG_2633.jpg
    Mike Moreau, brEad, loudbang and 3 others like this.
  19. Duke
    Duke
    Looks like you are getting close to driving!
  20. ss34coupe
    ss34coupe
    Getting there, too many projects at once is always my problem.
  21. ss34coupe
    ss34coupe
    Built the toe boards and modified the trans cover. A channeled car changes the proportion of everything it seems and so parts like toe boards have to be built from scratch. There are three pieces in all, the outer two in 18 gauge and the trans cover in 20 gauge. All are easily removable if work needs to be done in that area. The original trans cover is also modified to clear the shifter and emergency brake. IMG_2634.jpg
    brEad, duncan and loudbang like this.
  22. ss34coupe
    ss34coupe
    Chevbucket (John) got the fan spaced properly, and put in the rad hoses. The rad is an aftermarket one designed for a shortened 32 Ford grill shell and a Chev small block. The lower water pump outlet on the Cadillac 331 motor is on the left side, so John used two angled rad hoses spaced by a tube to reach the outlet. IMG_2638.jpg IMG_2640.jpg
    brEad, loudbang and Xman like this.
  23. ss34coupe
    ss34coupe
    Built the battery box in the stock location. A battery that fits a Honda Civic fits nicely. Still got to build a hold down and the floor cover. These jobs are endless.... IMG_2636.jpg IMG_2637.jpg
  24. ss34coupe
    ss34coupe
    In the 60's local rodder Len Mckay built a very nice 33 Ford five window coupe, and there was a picture of it in a 1969 issue of Rod & Custom magazine. The coupe has been in this area since, going through several owners. In the early 90's another local rodder named Andy Anderson acquired the coupe. He still owns it, and is going strong in his 80's. Recently Andy decided to upgrade the interior of the car, and took out the bench seat, door panels, headliner and other panels that Len installed so many decades ago. Last year I was fortunate to buy the bench seat , and this spring Andy sold me the rest of the upholstery. While it is worn and a bit tattered in spots, it will be perfect for my 50's style coupe build. LenMcKayVictoria33coupeinthe60s.jpg IMG_1495.jpg IMG_2616.jpg
    brEad, cactus1, 35cab and 3 others like this.
  25. duncan
    duncan
    Get it in there Steve. Lets have a look. I met Andy today, at Sid’s.
  26. ss34coupe
    ss34coupe
    John and I were working on the coupe today - got the throttle assembly working properly. This is a push set up, not IMG_2645.jpg a pull one, and John assembled it from parts I had laying around. Thanks to our friend Syd. M. for an assist on this part of the project.
    cactus1 and loudbang like this.
  27. duncan
    duncan
    That's a Rube Goldberg moment right there, good work on the inversion.
  28. Chevbucket
    Chevbucket
  29. ss34coupe
    ss34coupe
    Got the brakes bled, now working on the interior panels. More pics soon.
    loudbang, cactus1 and duncan like this.
  30. duncan
    duncan
    Did you start it yet? Need to hear it run, post a video.
