Hot Rods 33 - 35 Axle to Spindle... Is This Right?
Discussion in 'The Hokey Ass Message Board' started by nailheadroadster, Dec 16, 2014.
  1. nailheadroadster
    nailheadroadster
    Hey fellas, I need abit of info here.
    I recently got a front axle and spindles and am curious about the distance between the two and what configuration of washers, felts and shims would be required to make up the distance AND exactly where would they would go?
    Also, does the bearing go on top of the spindle directly below the kingpin?
    Pics would help a bunch!
    Thanks in advance! Dave
  2. Yes, on those, the bearing goes on top of the spindle. You do have the right kingpins, with the brake cup, correct?
  3. nailheadroadster
    nailheadroadster
    Thank you.
    I am using my 1929 Model A kingpins. The spindles have new bushings and have been reamed for the kingpins.
    Any thoughts on what takes up the .177" between the axle and the spindle?
    The axle measures 2.365".
  4. alchemy
    alchemy
    I've never seen that much space between them. Does the axle or spindle have any indication of wear?
    That said, you could probably still just take up the space with shims. The kingpin kit will come with some very thin ones, but you will need to source something much thicker. Make sure to assemble the kingpin with it's locking pin and then see where some of the space needs reducing. Nothing tight between the axle and kingpin though, as the spindle needs to be supported by the bearing only.
  5. scrap metal 48
    scrap metal 48
    July sedan 015.JPG The bearing goes between the bottom of the axle and the spindle.. The washer and felt washer goes at the top of the king pin.. Click on pic for larger size...
  6. In the top pic, the bearing is NOT inserted. Won't that take up the extra space (.177")?
  7. thirtytwo
    thirtytwo
    Before 37 the bearing was on top of spindle
    I have heard of maching 28-36 spindles to accept a small Torrington bearing , but I have never seen one... It's possible that space just may fit a bearing of some kind?
  8. nailheadroadster
    nailheadroadster
    As far as I can tell from my research, the bearing goes between the brake actuator cup of the king pin and the top of the spindle. As shown here.
    I thought the shims would then go between the spindle and the axle. Then below the axle, the felt washer cup, then the felt washer... but the cup and washer are not .177" thick... sooo.... :confused: Do I make a metal washer to go between the felt washer and the spindle?
  9. alchemy
    alchemy
    Looks like your pic of that 36ish assembly shows a thick shim/washer between the lower side of the axle and the spindle. Did your spindle kit come with anything that thick?
    I've never put together a bearingabovethespindle kingpin kit, so I don't know where the felt goes. Guess I'd better shut up.
  10. nailheadroadster
    nailheadroadster
    Nope... no thick washer, just four .010" shims in the kit
  11. nailheadroadster
    nailheadroadster
    Here's a pic of a 34... supposedly stock. I see the washer between the lower side of the axle and the spindle, but it doesn't look very thick to me... kinda like just the felt washer retainer.
  12. scrap metal 48
    scrap metal 48
    Wow!! I learned something today.. Sorry for the misinformation...
  13. Put it together, including the lock pin, the hold the spindle against the bearing. You can then tell how much gap is on either side of the axle. Shim on top of the felt retainer to keep the felt tight on the lower spindle eye; but not enough to take any weight off the bearing. Then shim the top side of the axle to minimize any play; but again not to take any weight off the bearing. There is usually only room for the felt and retainer cup; but wear from use with worn bearings and bushings over the years can open the gap
  14. nailheadroadster
    nailheadroadster
    Thanks Rich! Great advice. I will do that and report back.
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    Don't feel like the Lone Ranger, I didn't know that either. I thought all Ford axles had the bearing under the axle and on top of the bottom part of the spindle. Live and learn.
    Don
