325 Dodge hemi ignition upgrade
Discussion in 'The Hokey Ass Message Board' started by Topolino Kid, Jan 25, 2014.
  1. Tired on missing with the points in my hemi...but then i never have been able to id the points that came in it...and ya, I've asked and hunted....
    So I'm looking for upgrade...pretrox?? or??? trying not to break the bank on this one, but want good system when done...old school look would be cool...thanks
  2. George
    George
    If your NAPA store still has the paper catalogs they should be in it.
  3. Every set I've ordered and looked at inn the books are wrong...most of then mount wrong...headache i believe due to it being an industrial hemi..no stamped numbers...also no tag.....that's why i was wondering if i could get a drop in unit for the hemi
  4. nitrohemi
    nitrohemi
    Try a mopar electronic ignition. Need a longer distributer shaft from hot heads but that works great. Davis makes a hei style distributer but it's not cheap. Get a used mopar electronic a harness from Mancini racing and a orange box the make the shaft longer and you have liftoff
  5. George
    George
    If it doesn't have vacuum adv it should be replaced anyway.
    You can use a longer int shaft or cut & lengthen the dizzy shaft on the LA dizzy, Mopar Performance sells a points to electronic kit with the orange box, ect.
  6. nitrohemi
    nitrohemi
    That's right I made my intermediate shaft longer on my 315 dodge. It's been a few years. I run a mopar orange box with a firecore distributer that is just like the mopar one. I had a used one for a while the upgraded to a nicer unit last year
  7. Bent Wrench
    Bent Wrench
    Back yard engineering = he has the right shaft and base, just graft an HEI onto the top of it. Does he has access to a lathe and a drill press? (and maybe a welder)
  8. Alex D.
    Alex D.
    from Hydes, MD.
  9. dodge59
    dodge59
    new item that came out a little while ago for sb mopar and 325 poly/hemi .
    hei style
    just 2 wires and cheap.
    what a deal . On ebay . $44.00 ebay number 370809528293
  10. George
    George
    No mention of what brand it is. Hot Heads has Unilite dizzys made for HH that'll fit low deck Chr & high deck Dodges(didn't mention DeSotos).
