Suggestions for transmission to match to a 324 Olds. Replacing a six in a '50 Olds Club Coupe. Current tranny is Hydramatic from the six. Sent from my SM-G920V using The H.A.M.B. mobile app
I believe staying with an automatic would be quite easy; the old Hydra-matics were good units (though expensive). If you want to go with a manual transmission, the easiest way to go would be a stock '50 Olds setup. It has the Cad/LaSalle type transmission which is quite strong. However, unless you can find a complete setup including the clutch linkage, it may be difficult. If you have to do substantial fabrication in the clutch area, it may me easier to start from scratch, with perhaps a hydraulic clutch. At that point you would be limited in transmission choice to what you can get adapter plates for. As I understand it, the original Olds parts are one year only and very difficult to find. You might also try to find a selector setup out of a little later Olds ('51-'58), but they are just as hard to find and the transmission is inferior. I think someone on here is running a Muncie four-speed behind a Rocket; perhaps they will chime in here. Most likely, you are in for quite a bit of fabrication unless you can find something stock.
I have a freshly rebuilt 54 Olds hydro slant pan...…………...not listed for sale but could be bought for less than a rebuild cost
I will be selling off some Olds stuff soon in the classifieds. I do have complete standard shift setups for 303/324 which are 3 speed 37 Buick top shifter case with Olds V8 gears & shafts...incl bell, flywheel, fork, TOB, etc. I use this setup in my 32 ford and other builds. LaSalles & the one year 50 Olds "LaSalle type" transmissions are not easy to find parts for these days, like the syncro ass'y and 1st/reverse sliding gear, which often are needed in a ''well used'' transmission. also have a used 54 hydramatic. but you live too far away, and crating/shipping is a real pain. .
I have been attempting the same project. I think that I have the necessary parts for a Cadillac-Lasalle 3-speed setup but have been spoiled by the 4-speed Hydramatic. I have been told that it can be rebuilt and made strong enough to handle V8 power by adding additional clutch discs but have no idea if it will work. V8 linkage will still be needed. Other considerations are upgrading the brakes with 88/98 parts to improve stopping and possibly upgrading the rear end. The 88 differential case had pieces welded into it, I am told to to handle mushrooming caused by increased power.
I've been looking for a shoebox Ford to put my 324 in..ala Thunder Road.…..just have not found one yet
"I have been told that it can be rebuilt and made strong enough to handle V8 power by adding additional clutch discs but have no idea if it will work." It's single range, meaning it can't be held in 3rd unless modified and can't be shifted into reverse unless at a dead stop. You really don't want it.
Thanks for all the input. I'll be at the National Antique Olds meet in Shoreview, MN in a couple weeks. I hope to visit with a few folks about options. I'll probably stay with the automatic and will explore upgrades. I'll probably replace the differential. Lots to do on this project.
