Had my block on a stand for about 3 months, then as a short block, and now a long block for the last couple months with no issues. Posted using the Full Hot Rod H.A.M.B. App
It's drag racing starts that blow transmissions, that is revving up and dumping the clutch from a dead start. Take off easy and develop a little momentum, then you can give it the works with no worries.
4 leg stand from the rear mount works fine on the Olds. Some folks install a vertical support in the front to support the weight of the engine if you wish.
I used mine in the back where the tranny mounts. Sometimes I added another support at the front motor mount location, because they are heavy!
Just to update this thread. I did pickup a 324 from 54 Olds to put in my 41 Ford custom. Also have the front motor mounts. I am awaiting delivery of a NOS 176 tooth Olds flywheel. Talked with Wilcap and they said that the stock Olds flywheel is drilled to take the Ford "long" style bolt pattern PP, but I will have to use the finger type as a diaphram style is too thick. I should be able to use the stock starter as well with no clearence issue's. So what exhaust manifolds are you guys using? The 54 has the the front cross over pipe. The block hugger headers that I have looked at are designed for a remote type oil filter. Are you using later model Olds cast iron manifolds that dump in the rear? Thanks in advance for your responses. Torchie.
I am using a front dump 51 on the left and for the moment have just blocked off the front port on the right manifold and am using the rear port. Flanges are available so you could make your own which is what I may have to do later.
im using stock 50 olds 303 manifolds in my 46 merc dual exhaust,pass side has pleanty of room drivers side is tight but doable,some guys go single exhaust with cross over pipe,i made my own exhaust pipes and flanges are available as vtwhead stated
Thanks guys. looks like I will go with the stock set and do the DS front dump and the blocked port on the PS. I have seen the flanges and would prefer not to run a header style exhaust if possible. My concern with the crossover is weather it will clear steering drag links. I will know more when I set the engine in place. Torchie.
Yep, I think not a real good "HOT" rod setup. Probably good for cruising. But I once knew a guy who said he busted up quite a few early Ford trannies with a '56 324. He finally gave up on the Ford tranny. Not sure what he went to after that. I almost want to say Muncie. But can't remember now.
Seems about the same as a Nailhead to Ford Trans setup and I know a guy that has had one of those in his 40 sedan since the late 50's and still the same trans. Mine is going to be a cruiser not a bruiser so I think that I will be alright. Stock 41 suspension and skinny 16" tires. Torchie.
Austinrod is that ps manifold a oe item or one that has been modified. Can't tell from the pic but it looks like the outlet has been brazed on ?????
Looks to me to be a modified 303 manifold??? Notice there is no generator bracket as well. Looks like they cut off the rear dump/crossover connector. It will be interesting to see his reply. Nice piece of history on the instruction sheet. Pretty much jibes with what the Wilcap rep said. Pre 54 engines use a 166 tooth flywheel I think as compared to the 54 and up 176 tooth flywheel. My flywheel should be here tomorrow. Torchie,
Here pic of manifold Came on car when I got it plus Engine after being put back together And extra bits From Austinrod
Why not use two drivers side exhaust manifolds? You'll still have to use a remote oil filter, but they'll clear the stock starter, either on the drivers side, or passenger side. Here's mine done that way (I need to go into the garage and get a better picture): And here's an Olds powered pickup that Titus was working on. I'm not sure what exhaust manifold is being used, but I'd like to find one... Yeah, But good luck finding a set!
Info on Olds/'39 Ford box, Olds flywheel: '49-'50 Merc had Borg & Beck cover drilling on 3-finger pressure plate, used 10" disc. This made the clutch & cover a bolt-in. I used this setup in my '40 Coupe, with a Cad lower bellhousing to switch the starter to pass. side. 4 trannies later, I changed the trans to a '37 LaSalle...did the tailshaft and rear mount trick to early Ford torque tube. The big surprise came when I installed it...The LaSalle trans with modified Ford mount was 1.25" longer at the rear! Did some cutting/welding on the 'X' member, shortened the torque tube, and the change was worth it! The LaSalle had a tall low gear, (close to 25 tooth Zephyrs) and I loved the long stick... Never scattered the Cad box, car 'felt' torquey, gave the illusion of being faster than it was. Engine was 'mild', low 90s at the drags, but consistent.
Hmm. That one from Titus's thread looks like the generator mount was originally part of the manifold along with a rear single dumper. That 49 Olds doesn't have the gen mount.
I think the manifold question was in regards to your PS exhaust Manifold. It looks to have been modified. Looks like Olds switched to exhaust manifold mounted generators in 1952. Also the early 303's exhaust manifolds were switchable from PS to DS. Most likely that stopped once they mounted the generator on them.. I have yet to see a rear dump exhaust manifold with a generator mount like the pic of Titus's. Would be great to know what it is from. Torchie.
Yeah, the outlet has been brazed on. You can tell from the slight sweep in the manifold where the original outlet was at the rear of it.
Agreed. That's what I've been trying to figure out. Unless the mount was cut off a passenger side manifold and welded back onto the drivers side before being chromed.
I think that this is what Titus is using Speedy. http://www.ebay.com/itm/1952-Oldsmo...Parts_Accessories&hash=item1c47bf0234&vxp=mtr Torchie.
Yep, that definitely looks like it. 1952 Olds 98 passenger manifold. I'll have to keep an eye out for one with the generator mount and single dumper. @Paul, do you think there is enough meat on a 303 exhaust manifold to match the port to a 324?
