I am building a 32 highboy fenderless pickup and i want to know about running a 33 or 34 axle on the front. I have found some 33 and 34 axles for a good price but dont know if it would be a big deal to use them. I am running 37-41 spindles f100 breaks so original 32 stuff fitting doesnt make a big deal. thanks
Everything that fits the later will fit those years. If you use model A or later wishbones you will need two 1/8" spacers as the axles you speak of measure 2" at the wishbone mount.
IF Your running fenders ,Stay away from that set up.The brakes push you out to far and wheels will be hitting on inside lip of fenders ,I do know this ,I had to buy an aftermarket 2 inch at 46 .I also have truck brakes 48 ford...Reread your ok without fenders .........32-36 are the same axle ,Just check the spring width
