Any Tips or Tricks to lifting a vin # off a frame ? I can barely make out what appears to be a 7 but thats it. Thanks, Mark
the serial number should be stamped in three places...but two of those are under the body. is the body off the frame?
My late father used to use a type of acid to read serial numbers that were removed (sanded off) from frames, engines and firearms. He had a detective buddy that gave him the secret. Maybe if you ask a crime lab technician how they do it..it was a simple etching process though..
No motor or tranny. Yea the body is still on it (truck cab) I found the one in front of the firewall (unreadable one). I was told there is one on rear crossmember but can't find one there. Should be one under the cab, right? Thats what I was thinking , some type of chemical. I believe blasting will erode away what is left the numbers. Thanks, Mark
I've had good luck with hand sanding, the rusty dust will sit in the lowspots and make the number readable, only of course if the rust hasent gone to deep.
Take some grinding metal dust and sprinkle it on the number make sure the number area is bare metal and rub a strong magnet on the underside of the frame you might make it out. It worked for Magyver. LOL.
Should have included this link, if you got a frame with the frontend on it the first location is the best bet, just a cab, I would hope for the second location. I haven't seen many early frame numbers done well. I have a '46 piece that show's well, either monday morning or thay had a pneumatic by then http://www.vanpeltsales.com/FH_web/flathead_serialnumbers.htm
Mine has the number stamped on top of the drivers side framerail on top of the rear kickup, also in the area somewhere around the center of the door on top of the frame. One in front had been ground, could only see part of stars & 1st & last #, very faint.
