Technical 32 throttle pedal repair
Discussion in 'The Hokey Ass Message Board' started by OzyRodder, Sep 18, 2015.
  1. OzyRodder
    OzyRodder
    In my stupidity I have somehow managed to snap off the ball on the end of my throttle lever.
    Is it able to be welded it back on? It's pretty small so not sure if the weld would create a bind on the throttle linkage if not filed back down.
    Looking for advice on what I should do
  2. yruhot
    yruhot
    Maybe fire up the mig and build up a new ball blob on the end. Aint a welder on here that cant make a blob,lol. and spend some quality time with a file and whittle a new ball on the end. Go slow and keep retrying until it fits right. I know a pain in the ass but what about this hobby usually isnt. I also thought maybe some flux and a touch of silver solder might do the trick. I dont know what kind of pressure is on that point.
  3. tb33anda3rd
    tb33anda3rd
    1. Connecticut HAMB'ers
    i would cut a piece of an arm from a model A and weld it on, if i couldn't find another. i have A stuff around, and new A parts are cheap.
  4. The37Kid
    The37Kid
    X2 on grafting a Model A Ford end, an original one. Bob
  5. alchemy
    alchemy
    Bend the remaining arm over a bit more, and file away until you have a new ball there on the end.
    tb33anda3rd likes this.
  6. OzyRodder
    OzyRodder
    Fixed!
    Drilled a small hole halfway into the ball, used an old drill bit as a shank and inserted it and brazed it to the arm with a corresponding hole.
    A file now to tidy it up and back on the road.
  7. OzyRodder
    OzyRodder
