32 radiator and grill with model a cross member
Discussion in 'The Hokey Ass Message Board' started by 36el, Oct 3, 2012.
  1. 36el
    36el
    from sweden
    I am installing my radiator in a 32 frame with model a cross member, does some one have any pictures how you solved this thank full oh help
    Regards
    Peter
  2. Don's Hot Rods
    Don's Hot Rods
    from florida
    Not exactly what you have, but I have a 32 grille shell on a model a frame. I had the radiator people (The Brassworks) make the radiator with a 32 top tank and a model a bottom tank. That gave me the correct mounts so it could be bolted down to the model a crossmember.
    Don
  3. Atwater Mike
    Atwater Mike
    Don...He may be asking for a height spec as well. (the '32 rails ascend about 1.25" from the firewall to the front cross member)
    Yes, that bottom '32 tank would interfere with the flatter Model A cross member!
  4. Not really sure I understand you question,,but I used a Model A cross member under my Deuce frame and used a 32 radiator and shell without any modifications. HRP
  5. Bruce Lancaster
    Bruce Lancaster
    I don't know whether it bears on this problem, but '28-9 radiator mounts on crossmember are about 1/4" higher than '30-31.
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've never seen a 32 lower tank. I guess it is a different shape than a model a lower tank ? As I recall ( I had this radiator built over 20 years ago) when I called the Brassworks and told them what I was doing they told me to send them inside dimensions of my grille shell (shell is chopped 8.5 inches) and that they would put the model a lower tank on. When I got it the thing bolted right up.
    I can see where height may also be an issue if you are not chopping the shell, like I did.
    Don
  7. I used a Walker radiator(stock height) although I did mount the cross member at the lowest point,,so there was about 1/2" between the top of the frame and the top of the cross member,,I boxed that in. HRP
