Does anyone have pictures of the cowl feel and lower cowl of a 32 ford pickup. I am trying to fit a botched semi chanel and I would like to see what it is suposed to look like thanks.
The firewall I used on my pickup had quiet a bit of ax work preformed by a previous owner but the feet are correct. HRP Before paint.
Cordell, If you need to see one in person for pic's or measurement stop by and see Dave at Drive Line Service in south Wenatchee. I have to go there soon we could share a ride? Nice firewall HRP!
Yes,the '32 firewall is a separate piece,the 33-34 firewall is a part of the body,,we used a 34 body and a 32 frame and the attaching point was about 2" higher,,and has only one loop to bolt the front of the cab to the frame. The 32 firewall has 3 holes in the feet to bolt it to the frame. HRP
There are also little feet riveted to the cowl edge itself which are pulled down to adjust the attitude of the cowl for door fit...those are likely also an issue on a channeled body.
