hi,can anyone tell me if a 32 5 window coupe rear window garnish moulding is the same as a 32 tudor sedan rear window garnish moulding.thanks phil.
Edit: I reread your post and realized I was wrong about the depth of the garnish, as I was thinking of the glass size. Everyone is correct that the garnish mouldings differ in depth, as the tudor/fordor rear window does not roll down. Sorry for the misinformation, I'll slow down and read closer next time Posted using H.A.M.B. App.
According to previous posts here, the 5-window is different from the Sedan version. Sedan is 3/4" deep. 5w coupe is 1 3/8" deep. http://www.jalopyjournal.com/forum/showpost.php?p=9331940&postcount=4
The sedan is thinner I believe, because the there is not roll down window. The 5w rear garnish is a duck of its own, because of the roll down window and rare as hens teeth unchopped.
YES Different I had a 32 sedan garnish it's 3/4 " wide . The 5 window is 1 1/4" wide. A Hamber was kind enough to sell me the right one I needed. Also sedan worth about 1/2 of the 5 window.
