Technical 32 heavy axle with 37 spindles, wide five drums stock wheels, with 37 rear in a 31 A
Discussion in 'The Hokey Ass Message Board' started by nobby, Sep 14, 2020.
  1. nobby
    nobby
    will the wheels rub the fenders
  2. alchemy
    alchemy
    No. Those front axles are pretty much the same width, and I believe the brakes and wheels all assembled will be very similar too. The '37 rear may be an inch or two wider than an original A, but still shouldn't rub fenders unless you put really big rubber on those wheels.
    flatford39 likes this.
  3. nobby
    nobby
    thanks
    where are all the AV8 threads
  4. 2935ford
    2935ford
    My fendered roadster had a '39 rear with 7:00 16". Fit perfect.
  5. alchemy
    alchemy
    There ya go. A 37 rear is the same width as a 39.
  6. nobby
    nobby
    another....
    IF using a stock undropped 32 heavy axle, with stock 37 spindles
    stock a crossmember BUT reverse eyed spring
    then using a stock 40 steering box cross steer and stock unsplit wishbone,
    will the drag link hit the pan on an 8ba
    IF using the same height tyres, will the frame be nose up
    it cant be can it. 32 axle is 1.5'' lower than an A
    reverse eye spring is another inch?
  7. nobby
    nobby
    do 40 juice back plates directly swap into 37 drums, is there any machining required?
  8. 1934coupe
    1934coupe
    This A-V8 has exactly what yo asked about.
    Pat
  9. alchemy
    alchemy
    I can't answer about the height issue, but yes some 40 backing plates will bolt onto the 37 spindles. Actually 37 spindles are exactly like 40 spindles.
    gimpyshotrods likes this.
  10. Mr48chev
    Are his 37 mechanical brake drums the same as 39 Hydraulic brake drums though? That is the question he needs the answer to.
    I was thinking about running wide 5s on my 31 Vic before I sold it and never researched that answer. My made back when using T rails Tear drop trailer frame has wide 5 rims on it. I'd still like that look on the T modified that I will most likely build with the parts I didn't sell.
  11. rusty valley
    rusty valley
    yes, 37 drums the same as 39
