Technical 32 grill shell to radiator fasteners
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Jan 24, 2020.
  1. What type fastener head were used to mount the shell to radiator? Slotted, Phillips, Hex, something else...
  2. The Shift Wizard
    The Shift Wizard
    Are you hot rodding or are you restoring? :p
    bobkatrods and mountainman2 like this.
  3. No restoration. Just would like to know the basic head style to be close is all.
  4. nochop
    nochop
    from norcal
    1/4 20 hex on mine ( for now)
  5. ^^^^^ With hood in place why not use a hex head. @The Shift Wizard running it with out a hood.
  6. Slot head screw's were on my car. HRP
  7. DDDenny
    1/4" button head Allen bolt.
    Butler 32 and da34guy like this.
  8. alchemy
    alchemy
    I think originally they were 1/4" slot head machine screws. But now I have hex head bolts on mine. I have the hood welt covering them up.
  9. woodiewagon46
    woodiewagon46
    from New York
    If you were restoring your car the correct fasteners are 12-24 binding head screws, in S-2 finish. The entire kit is available from Third Generation Auto, the company that took over for Ray Nacewicz for $4.00 a set.
    stillrunners and tb33anda3rd like this.
  10. manyolcars
    manyolcars
    Henry didnt use philips. Those were designed for GM
  11. Aaron D.
    Aaron D.
    I used hex head and ground the head thinner so it would clear the hood.
  12. Corn Fed
    Corn Fed
    An original unaltered shell has holes for #12 bolts. If you use 1/4" you will need to drill them out slightly.
  13. Want to avoid that. I see to much of it but I'm also guilty of it but moving on from that phase.
    This one won't for some time.
    That's what I'm going use.
    bct likes this.
  14. Conclusion after being at GNRS today and looking at all the 32 shells. I'm going with slotted pan heads.
    nochop and low down A like this.
  15. WB69
    WB69
    My originals are 12/24 screw heads like woodiewagon46 said.
    deathrowdave likes this.
  16. jimgoetz
    jimgoetz
    What ever would fit. If I was building it for show whatever would fit that I had four matching of.
  17. low down A
    low down A
    designed for GM. what's the story on that i've never heard it. i do know you don't see phillips head till late 40's early fifties on all brands.
  18. DDDenny
    Cripes, I hate slotted head screws, bolts, etc, throw them away any time I can.
    26hotrod and Johnny Gee like this.
  19. I get it. But how often does a grill shell go on and off after mock up work is done using something else?;) I mean I hate all the prep work and sanding before paint. But it all about the look that matters, right?
  20. nochop
    nochop
    from norcal
    Grade 8 btw
  21. clem
    clem
    FWIW;
    By using hex, You can leave the hood felt/web in place ( mine is glued on ) and get a spanner to just sneak in between, - not with a screw.
    Mines been off 3 times in the last couple of years, but I run a Flathead.............
  22. terry k
    terry k
    from toledo oh
    My original had square nuts.
  23. DDDenny
    Whatever blows your dress up!:D
    I've never had luck keeping slotted type screwdrivers in the slot and I'd rather not take a chance of the screwdriver gouging something or skating across a nicely painted surface.
    26hotrod likes this.
  24. goldmountain
    goldmountain
    Due to the wonders of the internet, I discovered that phillips screws were invented in1937. However, Robertson head screws (a Canadian thing) came much earlier and I have found some that I believe were original on my Model T and old Henry did use them.
  25. woodiewagon46
    woodiewagon46
    from New York
    Canadian Model A Ford's had square socket drive screws (Robertson screws). I wouldn't doubt that if the Model A used them, Model T's also did.
    wackdaddy likes this.
  26. deucendude
    deucendude
    from norcal
    Doesn't matter much the heads are hidden anyway.
  27. And when there isn't going to be any welt to cover them?
  28. Deuce Daddy Don
    Deuce Daddy Don
  29. Deuce Daddy Don
    Deuce Daddy Don
    Anyone of choice, welting will cover them.
  30. Stove bolts were Phillips ?
