Technical 32 grill insert Id help (with a little pines photo op)
Discussion in 'Traditional Hot Rods' started by Binderman01, Dec 5, 2020.
  1. Binderman01
    Binderman01
    I've been fooling around assembling my pines this morning, and going through boxes of parts. Trying to figure out what this second insert was/is. This is all I have that I've found, but I can't find IMG_20201205_112730.jpg IMG_20201205_112801.jpg IMG_20201205_112746.jpg any good pictures from behind a factory insert to see if that's what it is/was.
    kidcampbell71 likes this.
  2. The first surround is for a regular 1932 insert, the bars are missing. HRP
  3. Binderman01
    Binderman01
    Thank you that was my first assumption, I assumed the surround would be polished. And couldn't find anywhere if the bars were removable or not
  4. Fordors
    Fordors
    That surround is missing the stainless cladding and the crank hole. Yes, the bars are removable, those two horizontal pieces have a bit of “tooth” that grips them and the ends of the bars were bent a bit to keep them secure.
    X38 and Binderman01 like this.
  5. Binderman01
    Binderman01
    I found the stainless cladding, no crank hole though.
    Do the round holes in the horizontal bars do anything? Then what holds the stainless cladding onto the insert?
  6. alchemy
    alchemy
    There are a few different versions of 32 insert. Most have the stainless cladding crimped around the steel backer. Some have a wide stainless front that wraps all around the side. Others just a thin stainless. But they both look the same when all assembled.
  7. [​IMG]
  8. lucky ink
    lucky ink
  9. Fullfendered
    Fullfendered
