My 32 crossmember measures 3" and the u bolts and bracket I got measures 2 and 3/8 dose anyone know why or if any one could measure your crossmember and report back so I can see if I'm crazy or if I have the wrong bracket and bolts there is no listing for measurement for this Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
I have a socal bracket that is supposed to be for 32 ford front crossmember but it dose not fit over the crossmember holes won't line up not even close Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
I will get pics when I get home 32 car I just need to know if anyon e has a 32 out there if you could let me know if it measures 3 inch or 2 and 3/8 the flat part of the spring perch Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
Or the space between the thread on the flat top u bolt Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
My problem is I can't seem to find u bolt measurments anywhere on the Internet the story go's I have an old rusty 32 frame that was customized prob in the 60s? It looks to me to be a 32 crossmember and looks to be original. So I ordered a spring bolt kit for 32 ford and it don't fit so I call socal and they say it is the correct one so it is either package wrong or the Fram I have has a different crossmember I will send pics Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
A stock 32 crossmember measures 2 3/8 across the center bolt hole. Here is a photo of mine. I raised it 1 1/2" but the distance stayed the same.
Ok mabe someone put a truck crossmember in my frame or well I don't know who knows but thank you pewsplace that answer my question. So I guess from here I need to find out what crossmember I have so I can reorder u bolts and new bracket I think model t would be smaller so mabe it is 32 pickup or camercial or mabe 35 to 48 I have a 48 front end on my model a mabe the ubolts on that are 3 inch mabe it a 35 or 40 ford crossmember ohh well more Internet searching. Thanks again pewsplace Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
Thanks guys for the info I ended up just making my own spring bolt kit and it turn out really nice Sent from my SAMSUNG-SM-N900A using The H.A.M.B. mobile app
