Anyone that has the stock closed car dimensions of a windshield, or can measure theirs, please post it. Trying to find out if this is a 32 Ford or not.
I just sprayed mine and it was drying so these are as precise as I could get w/o mucking things up. 28 3/8" between the hinges. 43 1/4" wide at the bottom 13" tall measured at the hinges
Looks to me like a 32 Ford sedan or 5 window windshield. I would measure mine but I only have 32 3W or 32 roadster windshields
Thanks for the help...I took some more accurate measurements, along with a picture. Both height and width measurements were taken from the front side. Third measurement I took is from the backside. Measured from the middle screw on both brackets. 31 inches between the two.
Those are not the dimensions I have. My windshield frame is 12 1/2" tall in the center and 43 1/4" across the bottom and gets wider towards the top corners. The face of the frame 1" wide.
