Hot Rods 32 Ford Spindle spacer
Discussion in 'The Hokey Ass Message Board' started by 41Stude, Mar 28, 2019.
  1. 41Stude
    41Stude
    I have 32 Ford spindles with the spacer for disc brake conversion. Does that spaceer have to be pressed on? Mine spins freely. Does that mean it’s the wrong size?
  2. bct
    bct
    Yes should be a tight fit. The seal rides on it. Try and shrink it by heating and quench or even just a slow cool
  3. 4wd1936
    4wd1936
    from NY
    bct is correct, if it is not actually loose a spot mig on the back might work or even loctight.
  4. 31Apickup
    31Apickup
    I haven’t seen disc brake conversion for 32 spindles, they are usually 37-48 spindles.
    Fordors likes this.
  5. 41Stude
    41Stude
    These are advertised from 1928 to 1948 ford spindles
  6. 31Apickup
    31Apickup
    Do a search for a thread called “40 Ford Brakes on 32 spindles quick tech” it gives what is needed to swap the later hubs to 32 spindles. If you truly have 32 spindles the disc brake kit isn’t going to work.
  7. alchemy
    alchemy
    Lots of parts "vendors" advertise stuff that isn't true. No such thing as a 28-48 Ford spindle. Quite a few different measurements in the spindles of that timeframe.
  8. The '28-'36 spindles have a smaller bolt flange than '37 up, spindle snout length and inner seal is different on the early spindles and changed in '35 and different again in '36; so a single kit can't fit '28-'48.
    I have never seen a disc brake kit made to fit pre '37 spindles.
    Maybe need to ID what you are working with.
  9. Fordors
    Fordors
  10. Ned Ludd
    Ned Ludd
    You wouldn't happen to have that info available for the respective parts? i.e. length of snout, length of inner bearing seat, length of outer bearing seat, etc.? It'd be useful to me.
  11. Bruce Lancaster
    Bruce Lancaster
    Rough reply...all 28-48 use same bearings. Long spindle snout is '28-35 and needs the small bearing spacer to use late hub.
    1936 and up use the shorter snout and so need no small spacer for hydraulic hubs. The larger "piston ring" spacer to fill the center hole on hydraulic brakes is needed '28-36, except some Lincoln hydraulics kept the smaller hole longer.
    Moriarity likes this.
