OK i have come to a decision. I am going to run the 34 rear end for now because its a bolt in application and my motor is a stock 21 stud with 80 hp on a good day.When the finances present themselves i will rebuild the motor with lots more hp and redo the rear end to the 36..
Wrong! All got the Model A style until late in production when they all got the later style with the straddle mounted pinion and splines.
the 4 cylinder and v8 toque tubes are supose to be different lengths from what ive heard. dunno if its true or not. i know for a fact 33 and 34 are that way. jeff
The 32 4 and V8 tubes and shafts are identical . The 33-34 tubes and shafts were different between the 4 and the V8. This was accomplished by having the trans.mount. reversible so to accommodate the different lengths.
not true. it is early and late. i have 2 late '32 trucks with the 33-34 "style" rear ends from the factory, and they have 4 cylinders. my early '32 trucks have model A style rear ends with 4 cylinders also. -danny
And thats why i had the "dunno if its true or not" on the end of my statement, henry ford did lots of crazy stuff.
Great guys! Did I just read common rears & common courtesy in the same thread? The way to communicate for sure.
