Hello hambers i got a quick question or two about a pair of 32 ford doors... I believe they might be 32 5 window but am not sure what dimensions for 32 5 window stock doors are? and if 32 2 door sedan use a wider door? does any one have any possbile measurements for 32 closed car doors and what model closed carsuse the same door? and what are they worth/ go for? They are very solid unmolested n one is very straight the other needs couple dents fixed n no rust!! thank u hambers
27 5/8 at the door lock wideth.could be 27 3/4 at the middle hinge. my car is chopped so can,t give the heighth. ski
My Vicky is 35.5" wide at door handle. I think sedan is same but higher at door glass area. Could be wrong.
My 32 sedan is 35 3/4 at door handle. ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Like I told the kid,"Your music's not too loud, its just like OKC, it sucks!"
BTW my vic is 43 1/4 high, and as I said before 35 1/2 wide. So that follows my theory that sedan doors are near same width, but taller.
A friend just told me that 5w doors are close to 4dr sedan fronts also. The very top of the door has a slight angle difference.
The only 32 doors I've sold recently were a pair of fairly good 4dr fronts for 850.00 less moldings, latchs and window rollers, but with nice solid hinges and inner panels. Just needed the bottom outside 3 inchs.
