I am hoping someone can help me out with a few measurements on my 32, five window coupe. Right now the floor is gone, leaving the body a little wobbly. I am looking for the distance for the center of the outer, lower hinge bolt hole on the right side to the left, outer, lower hinge bolt hole. Also, the distance from center of the lower bolt hole on the door striker plate on the right side to the center of the same hole on the left side. And lastly for now, the distance from the center of a bolt hole on the left rear inner fender( hole closest to the front of the car) to the center of the same hole on the right. If anyone could give me these it would be a big help, thanks Steve
I come up with following: "A" pillar door hinge screw center is 42 3/4" "B" pillar dovetail screw center is 49 3/4" Sorry I can't give you the wheel well fender cage nut as trunk is finished and can't access for that dimension.
Mine is; Lower door hinge outboard screw 42 1/4 Lower striker screw 48 13/16 I have put a new floor in, but may not be exactly where Ford put it originally. But, everything fits right now so that where its stayin!
