Projects 32 Five Window highboy
Discussion in 'The Hokey Ass Message Board' started by koolbeans, Dec 30, 2018.
  1. koolbeans
    koolbeans
    Yes, a shroud. I'll form a horseshoe with "L" tabs and mount it to the radiator shell. Will post pics.
    Sent from my XT1710-02 using The H.A.M.B. mobile app
    Fordor Ron, Thor1 and loudbang like this.
  2. koolbeans
    koolbeans
    Another helpful tidbit....while closing in on the end....using "British" push together "butt" connectors. I use them for anything I might intend on removing for service: dash, headlights, taillights, etc.
    They are simple, do need a special crimping tool for the wire end bullets.
    But, easy to pull apart when you have to. IMG_20200612_082053572.jpeg IMG_20200612_082239834.jpeg IMG_20200612_110053200.jpeg
    Vic Walter, loudbang, brEad and 2 others like this.
  3. koolbeans
    koolbeans
  4. Thor1
    Thor1
    Man!, that sounds nice!
  5. Arduns sound like a real engine. :)
    loudbang and Thor1 like this.
  6. koolbeans
    koolbeans
    brady1929, loudbang and Thor1 like this.
  7. loudbang
  8. koolbeans
    koolbeans
  9. koolbeans
    koolbeans
    A smidge off the thread direction, but someone else posted one like this, I believe cornhusker. With his thought of grafting this Anglia dash I pulled mine out. It's 2" each end short of full width '32 Ford dash. But I'ma sure someone could figure the artful fit. I save this stuff as paying homage to the ol school tool and die craft. This is made outa "bakelite". IMG_20200624_095606923.jpeg IMG_20200624_095756863.jpeg IMG_20200624_095613557.jpeg IMG_20200624_095652946.jpeg IMG_20200624_095712134.jpeg
    loudbang and teach'm like this.
  10. koolbeans
    koolbeans
    Well, the clock and calendar waits for no one....crawling to the finish line....the hare and the tortoise... IMG_20200712_123525707.jpeg IMG_20200712_122815592.jpeg IMG_20200711_134727811.jpeg IMG_20200711_101334711_BURST001.jpeg IMG_20200711_101312592.jpeg IMG_20200710_124515998.jpeg IMG_20200710_124041006.jpeg
  11. chop job
    chop job
    from Wisconsin
    1. WISCONSON HAMBERS
    Love the fenders are you going to keep them and run rear fenders also? IMG_20200131_165130343_2.jpeg
  12. koolbeans
    koolbeans
    Considering? Thinking to make them easily removable. Rears the same way?
  13. koolbeans
    koolbeans
    Well, as the inch-a-long continues...circling back around....
    Completely rehabbed the E&J's..mods for high and low halogen lamp with adaptor I made, parking lamp, kellerman turn signals, clean all the brassie, paint, rewired. Introduced "jose cuervo" to calm the nerves... tedious and time consuming now the Packard doo to put them into operation.. IMG_20200716_145607855.jpeg IMG_20200716_115242800.jpeg IMG_20200716_105129664.jpeg IMG_20200716_143902090.jpeg IMG_20200710_124511366.jpeg IMG_20200710_123919108.jpeg IMG_20200710_124041006.jpeg IMG_20200712_122815592.jpeg IMG_20200711_134703096.jpeg
    shortypu, Thor1, brEad and 3 others like this.
  14. koolbeans
    koolbeans
    I failed to point out (jose probably blurred my cranium), that the typical E&J model 20 has 50 plus pieces/parts to the assembly. Incredible for after markets headlights let alone for the early '20's era. If you look at the patent doc typically found its clearly short on showing all the pieces. I know, I've counted and compared. They are an engineering/manufacturing collasal feat. Especially at an optional price of $48 in the '20's.. IMG_20200712_122815592.jpeg
    Thor1, Vic Walter and loudbang like this.
  15. Atwater Mike
    Atwater Mike
    Ultimate...Just ultimate.
    Amazing, the profile/stance. My red '32 Hiboy (1959) sat close to identical. (4 jug flathead, Hali Quickie, reversed Merc steelies, Merc caps)
    A sound recipe, to be sure. '32 5 window, tall.
    At 77, I remember the Bear super clutch. My knee...Ow!
    Thor1, loudbang and koolbeans like this.
  16. koolbeans
    koolbeans
    Mike, hate to lay down, but the '32 has a 200R4 due to new knees, new hips, back surgery, and worse: Arthur Ritus....plus many other non-original goodies.
    My German father-in-law famously said frequently..."jim, it's a damn site easier getting here than outa here". No truer words ever spoken.
    Thor1, loudbang and HemiDeuce like this.
  17. koolbeans
    koolbeans
    E&J's......powered up.....parking lights then halogens......dynomite.... IMG_20200718_105723598.jpeg IMG_20200718_111246528.jpeg
    Vic Walter, shortypu, jnaki and 4 others like this.
  18. koolbeans
    koolbeans
    As the inch along process moves along towards the end, now fitting the hood and hold down straps. Hood a challenge to get margins right or close. (There is no right). Per Rootlieb, weld on extended edges and grind back to your liking. Huh.
    Didn't like the first trans tunnel so why not make a new one. Patterned out.
    Hood sides next. Patterns. Making blisters for the fat Ardun heads.
    Take a look closely at the teenie- weensie turn signal lights on the E&J headlight mounts. These are so kool!!! Kellermann, German, for motorcycles, the size of a common pencil eraser. Do not, and I stress do not look directly into them. You will not be able to see for 10 minutes +.
    Well, there's more....next time. IMG_20200804_163235138.jpeg IMG_20200802_120952003.jpeg IMG_20200802_120931068.jpeg IMG_20200801_094222310.jpeg IMG_20200804_160733421.jpeg IMG_20200804_160717434.jpeg IMG_20200730_143827990.jpeg IMG_20200730_082449916.jpeg IMG_20200728_095121230.jpeg IMG_20200728_094958600.jpeg
    Vic Walter, shortypu, brEad and 4 others like this.
  19. koolbeans
    koolbeans
    Well finally stepped over the edge. With the Ardun I had the chassis built two inches longer to minimize cutting the firewall and at same time keep the package looking reasonably original.
    Rootlieb to the rescue with a 2 inch longer hood. Very nice product.
    But I new from the beginning that the original hood didn't square up and figured the new one wouldn't either.
    Sure enough. Needed massaging.
    Pics show process of patterning and adding 5/16" to back end of each hood side. Not hard...just had to tighten the "go-naddle" support and dive in...and with minimal heat as possible.
    Cut and grind back the excess and off to priming. Not a Riddler fit but more better than original.
    Note: when I surveyed the '32 constituency about the hood fit and suggestions from Rootlieb, the answer was what are you waiting for. IMG_20200801_094157673.jpeg IMG_20200810_135841836.jpeg IMG_20200811_092532104.jpeg IMG_20200811_101525365.jpeg IMG_20200810_163038838.jpeg
    Vic Walter, brEad, Fordor Ron and 5 others like this.
  20. koolbeans
    koolbeans
    Hood back for trial fit before final paint. Certainly better than before.
    Made up and trial fit hood strap hold downs. A little different treatment. Seats off to re-covering doctor. Juteing out the floor for carpeting. I know it ain't horse shoes...but getting closer. But it's exciting. IMG_20200816_085651582.jpeg IMG_20200816_085527736.jpeg IMG_20200816_085542342.jpeg IMG_20200816_155629308.jpeg IMG_20200816_124543497.jpeg IMG_20200817_152311122.jpeg IMG_20200817_151600156.jpeg IMG_20200817_151540672.jpeg
  21. koolbeans
    koolbeans
  22. koolbeans
    koolbeans
    IMG_20200825_165022364.jpg IMG_20200824_103400788.jpg IMG_20200825_165022364.jpg IMG_20200824_103400788.jpg Moving along....fitting out the interior.... definitely a competition with Arthur-Ritus....pushing, poking, cutting, cussing and discussing....next....rumble from the "Porters"....zoom, zoom...
    Just Gary, brEad, Vic Walter and 2 others like this.
  23. loudbang
    This build is living up to your user name. :rolleyes:
    Thor1 and brady1929 like this.
  24. what are the seats out of? I could never do this but if I could, we see a lot alike....
  25. koolbeans
    koolbeans
  26. koolbeans
    koolbeans
  27. koolbeans
    koolbeans
  28. koolbeans
    koolbeans
    Stromberg 97's....teething issues. Only two carbs functional. Thus operate at this moment simultaneously. At idle, or dropped throttle getting way to much fuel thus burps, farts, stalls, stops....
    I assume now that the two carbs need to be set up progressively, therefore operating at idle and just off idle on only one carb. Thoughts, opinions and suggestions.
  29. Love how this car is turning out. I Would like to see it outside with the green wires on it too.
  30. koolbeans
    koolbeans
    Me too. Will try soon. Maybe this coming week.
    Lots of work to change as what's there now are the real deal knock offs. Lots of parts. But....the DeWalt battery torque wrench is a savior.
    Will post soon.
    Fordor Ron and loudbang like this.
