Are you working on 8 Chevrolets with 32 brakes or is it a 1932? What make, Ford? Original brakes (later hydraulics, if so what are they)? Front or back? Where are you stopped, are the hubs and drums off of the car? Charlie Stephens
they are gennie 32 brakes jetmek helped me said i need a brake puller thanks guys.......thats for the back dont know if fronts the same
Buy a good puller, expensive but cheaper than axles. Or maybe borrow one. I use the reproduction KR Wilson puller. Well worth it. Charlie Stephens
Don't need a puller for the fronts, just a large wrench to take the nut off the end of the spindle. On the front, the hard part is if the mechanism and actuating rod through the kingpin is rusted. Otherwise it's just a bunch of regular bolts.
