'32 3 window turn signal ideas
Discussion in 'The Hokey Ass Message Board' started by 4t6ford, Dec 1, 2010.
  1. Ragtop
    Ragtop
    I used the same lights on my '34. I also made one into a 3rd brake light. I know that might not be traditional, but my '47 Chevy tailghts don't show up very well at all.
  2. Ragtop
    Ragtop
    oops! forgot the attachments
      497.8 KB
  3. Ragtop
    Ragtop
    here's the front one
  4. Clever!! Nice car too!
    Could create a shortage for the '50s Chevy guys if a trend begins... :D
    -Dave
  5. Yamanine
    Yamanine
    Motorcycle turn signals off Amazon. They are sequential with little arrows. $14
    TCATTC likes this.
  6. I use the big stock headlights with the turn signal inside the light on my 32 5 w
    & on my 34 ford pick-up . I do not like hang on turn signals as it spoils the flow &
    the lines . Makes it appear like an after thought (like O-well lets hang them right here). On fender cars , I like turn signals in the cowl lights.
  7. JWL115C
    JWL115C
    Lots of good ideas here. I too have been thinking of front turn signals for my avatar pictured 3-window. The front end is so clean and adding any lights is going to take away from the look. I don't want to modify the attractive BLC headlights. Considering cowl lights painted black to match the body color. But, this would require holes in the body. Also thinking about those small round lights that fit into pickup bed rails. They are small and would not be too visible until lit up. Turn signals were fitted to the rear and incorporated into the 50s Pontiac round lights.
  8. Hotrodmyk
    Hotrodmyk
    1. Northwest HAMBers
    Using motorcycle lights off Amazon. Small but bright.
  9. Joe Blow
    Joe Blow
    I used vintage Harley turn signals with my BLC's.
  10. DDDenny
    I haven't decided on the lights yet but I got the switches.
    Splitbudaba and Just Gary like this.
  11. I used these small lights off EBay on my 32 Tudor, as they came closest to matching the shape of my BLC 682-J’s. They come flat black with smoked or clear lenses.
    Painted to match your frame color, they would be less noticeable.
  12. Kiwi 4d
    Kiwi 4d
    We have the little pommy side markers with an amber bulb down low on the frame rail, and in the rear we simply use LED 32 lights with the appropriate turn signal unit to cancel tail lights ,bright as so everyone says. The front turns also have the appropriate dot numbers ,if you care. Down under i dont believe a new build can use turn signals in the headlight now ,though its the perfect place for them.
  13. JWL115C
    JWL115C
    Bob Drake sells a cowl light with a two filament 12-volt bulb for parking and turn. May go this way and paint the lights to match the body.
  14. JWL115C
    JWL115C
    Decided to go with some accessory turn-run lights from Harley Davidson. Did not want to drill holes in the body for the cowl lights. I'll post photo when job is done.
    pprather likes this.
