Technical 32’ cowl vent in A roadster cowl
Discussion in 'Traditional Hot Rods' started by dsiddons, Jun 29, 2020.
  1. dsiddons
    dsiddons
    from Indiana
    Looking at putting a 32’ cowl vent into a 28’ roadster cowl. I don’t have the part in hand so was wondering if someone has done this and has any inputs. IMG_9666.JPG
  2. I did that on my Roadster. Started by cutting the bottom of the tank, just leaving about 3/4" all around.
    Cardboard template, centered it well, cut it out and weld it slowly....taking my time not to warp it.
    Some dolly and hammer is needed around the corners.
    I used the same unit as the one you pictured and it was easy to work with. I believe there is an original for sale in the classified section....
    thumbnail_IMG_2714.jpg thumbnail_IMG_2715.jpg thumbnail_IMG_2716.jpg thumbnail_IMG_2719.jpg thumbnail_IMG_2720.jpg thumbnail_IMG_2721.jpg thumbnail_IMG_2722.jpg thumbnail_IMG_2732.jpg
  3. dsiddons
    dsiddons
    from Indiana
    That looks like a 30’ cowl thou?
  4. dsiddons
    dsiddons
    from Indiana
    Maybe trim it down for a 28’?
  5. sloppy jalopies
    sloppy jalopies
    Done this a few times, great for '30-'31s...
    but the '28-'29 cowl has too much compound curve for the '32 cowl top / vent...
    maybe if it was down sized,
    make paper templates for sizes and for the arches in both directions,
    plot the tank top with the paper, maybe a '32, or 3/4 of a '32, or a little different 1/2 of a '35-'36...
    non-ford options are out there [ they repop the ford stuff, other's don't] ...
    if big cut to your size...
    the smaller the vent the better it will fit... go dsiddons go !
    dsiddons likes this.
  6. dsiddons
    dsiddons
    from Indiana
    Well sitting here in some thick humidity and was thinking wow how nice it would be with some relative wind in a swamp ass roadster on hot summer night. Thanks
    lothiandon1940 likes this.
  7. brady1929
    brady1929
    Looks cool.
  8. uncle buck
    uncle buck
    That was my thought
  9. Yes, my bad ,that is a '30.
    I didn't know there was a difference on the 28-29.
    If useful, the United Pacific unit I used was easy to work with, allowing tweaking to the corners to better match the profile....not sure how much curve there is on 28-29
    The flange had a good amount of meat on it to allow shaving/adjustment for the curve.
    dsiddons and lothiandon1940 like this.
  10. el Scotto
    el Scotto
    from Tracy, CA
    If you're clever you can find a way to adapt anything. I put a 1930 Franklin cowl vent into a 30/31 Ford cowl and it was pretty easy.
    kidcampbell71 and dsiddons like this.
  11. The37Kid
    The37Kid
    Model A trivia: the early 1928 Fordor had a cowl vent on the drivers side only. Never seen one in real life, wonder what the size and curvature is. Bob
    hotrodjack33 and dsiddons like this.
  12. Never2old
    Never2old
    from so cal
    I planned on putting one in my truck. I had an original door and ordered a repair kit (2 pieces) from Brookville.
    The stuff I got didn’t fit together and was at least two gages thinner than the tank. Left the fill cap and sold the pieces at the LARS.
    05snopro440 likes this.
  13. sloppy jalopies
    sloppy jalopies
    model T gas filler cover sits ontop but the cowl shape is very close...
    buddy used a jeep vent, sits ontop,
    when he swung out the w/s then popped the vent the w/s frame would lean back against the leading edge of the lid... worked great... my $0.02 ...
  14. Just keep your gas cap. Buy an extra and louver the top. Been done many times. You just need to know where the louver will fit when tight.
  15. alchemy
    alchemy
    My little brother welded a cowl vent from some off-brand (Studebaker?) cowl into a 28 Ford cowl once. It had more curve than a 32 Ford.
  16. I had a '31 Vicky back in the 70's.It came with a cowl vent on the driver's quarter. It was flush and very well installed. I never saw any others and the old restorers had never seen one. Whoever did it was skilled. With it open and the w/s popped there was plenty of air flow.
    Tman likes this.
  17. dsiddons
    dsiddons
    from Indiana
    Maybe make one out of aluminum like a old aircraft cowl flap off a T-6 or something?
  18. sloppy jalopies
    sloppy jalopies
    if it gets small enough you will start looking at pick up truck gas filler doors... junkyards full of them...
  19. Did some Murray bodies have the vent.
  20. buford36
    buford36
    from Maine
    charleyw, harpo1313, brEad and 4 others like this.
