New Build Custom Built Body Thick fiberglass body steel reinforced doors cab steel floor Engine 350 Corvette ,Completely fresh ,Coated pistons std. standard rods and mains ,375 Fuely Cam. Edelbrock manifold ,new 650 Holly electric choke, HEI Ignition Stainless Block Hugger Headers 2 1/2'' Exhaust , Flow Masters 350 Turbo Completely Rebuilt Shift kit, Brass washers Hi Performance Clutches ,Speedway Balanced Drive shaft New U joints Rear End 10 Bolt Chevy Factory Aluminum Calipers 342 gear , front disc also. Chassis 2 x 4 Tubing tapered in front- frame horns and dropped cross member ,Drop out trans mount Triangulated rear suspension with coil over shocks, 4 in. drop front axel drilled , fire wall mounted chrome master cylinder. 15 gallon Aluminum fuel tank , Chrome Tilt column with column shift Banjo steering wheel ,12 circuit wiring harness 6 Dauphin gauges with tack. custom made seat with slider new upholstery beige with off white rolled and pleated Paint is very nice Blue Pearl, base coat clear coat.. No Trades.,any questions call Bob 386 338 5783
