318 poly what carbs to get?
Discussion in 'The Hokey Ass Message Board' started by mosquito13, Aug 1, 2010.
  1. mosquito13
    mosquito13
    from sarasota
    coronet 007.jpg have a 318 poly in a 64 polara 440. it has headers and 3" exhaust,steet cam, electronic iggy, other then that its a stock engine. just picked up a stock dual quad intake for it. thinking quadrajets but realy need some advise here. this is my second car and 1st dual carb set up. so what type & size carb's should i get. any one got a simular set up , up and running? pic of whats on it now.
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    The Quadrajets would require an adapter which would impede flow,older AFB Carbs would be ideal or Edelbrock 500 CFM Carbs.
  3. George
    George
    Yup! Not sure on a '64 intake if the bore holes still have to be opened up like on the earlier WCFB intakes for the Edelbrocks, or if they were a bit bigger by then.
  4. Abomination
    Abomination
    EXACTLY.
    AFBs were stock, anyway. You'll have a hard time getting any other carbs to fit.
    ~Jason
  5. brad chevy
    brad chevy
    Get you a couple of thermoquads which were used in MOPARS to help absorb the heat from the engine,they will bolt right on and are easy to maintain,you definitly don"t want to use Holleys on it.
  6. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Thermoquads will not "bolt right on". They'll need the same adapters that the quadrajets would.
  7. Abomination
    Abomination
    Exactly.
    They were made for AFB's, dude - use an Edelbrock if you must, but the right AFB will run better. ;)
    ~Jason
  8. AFBs or Edelbrocks - a pair of 500's would work nicely
  9. mosquito13
    mosquito13
    from sarasota
    anyone running a dual on a poly?
  10. swifty
    swifty
    Nope. Running tri-powers on both of mine and before that I was running a single 4 on a Weiand manifold. For some reason, and it's probably due to the cost of fuel very few people run dual 4's here in Australia.
    swifty
  11. 73RR
    73RR
    Given that the 318 is mostly stock, I would recommend the WCFB. They worked well on the C-300 and 300B.
  12. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    I ran 2 500 edlebrocks on my 59 poly motor, but it was a Wiend intake. Worked great. Gary
  13. mosquito13
    mosquito13
    from sarasota
    hot rod roadster, your engine just became my screen saver. eddies got the vote now. more $ than i was hoping to spend , but knew that getting in. no more messing will research prices on a pair . and order.
  14. George
    George
    Depending on your carb expertise...you can talk to Edelbrock & tell them you want 2 set up for your application, the engine is a bit small for 2 500s.
  15. 29Jay
    29Jay
    from Ft Worth
    I like me some Polys.... mmmmm
  16. Does anyone still make 4bbl inlets for the 313/318 poly?
    I'd like to change out my 2bbl for a 4bbl...cast or alloy, dont mind which.
    Not much hope of finding one in NZ:(
  17. George
    George
    Nope, Weiand made them way back, hard to find now. 1 shows up on EBay every now & then.
  18. hot-rod roadster
    hot-rod roadster
    from Omaha Ne.
    On mine we had bumped the compression a bit with a dome'd piston and had the cam re-ground. Ran hard and never had any problems. Gary
  19. Abomination
    Abomination
  20. mosquito13
    mosquito13
    from sarasota
    ended up with a set of carter afb's 500 cfm . came with a fuel line kit and a s/s linkage. need to put a rebuild kit in 'em. have rebuilt amals and mikuni's but nothing for a car. will start up a new thread on rebuilding them. abomination thanks for the link. been trying to find that group. three views and the manafold
  21. Abomination
    Abomination
    No prob, man.
    Anything you need, feel free to hit us up on the Yahoo Group anytime. Bunches of us have parts, etc you may need. :)
    Running that intake, you might want to buy a matching cam...
    ~Jason
  22. storm king
    storm king
    AFB's or Eddy's
  23. mosquito13
    mosquito13
    from sarasota
