31 Studebaker...ryno goes hot rod
Discussion in 'The Hokey Ass Message Board' started by ryno, Oct 28, 2012.
  1. ryno
    ryno
    building this for a customer.
    31 Studebaker president sedan.
    car was originally modified with some crude fabrication in the late 80's?
    either way i cut out all the old and made new.
    chassis calls for a spring behind 4" dropped,cross steering,2 link rear with pan hard,air bags,boxed stock rails,tube x members
    old chassis
    pressure washed.squared up and leveled.cross braces installed.
    box plates started.
    new fab'd x member. this frame is about 2 " wider then a typical a frame,so i had to made the x member. it will get some lighting/speed/coolness holes installed and more structure added to it when it disassembled for powder coat.
    old vs new x member
  2. ryno
    ryno
    rea link bars.
    2x2 1/4 wall. 1 1/8 adjustable rod ends. over kill yes!
    start of tube work
    dimpled hole bracket
  3. jimmy1931
    jimmy1931
    Good Stuff, Ryno!
  4. Mopar Jack
    Mopar Jack
    I love me some old Studs...
  5. Trophydash
    Trophydash
    from Tulsa, OK
    Studebaker?! Had to see it for myself! Beautiful work!
  6. ryno
    ryno
    thanks for the good words fellas,
    here's the only pic of the body i have now.ill post some more when i start the floors.
  7. aircap
    aircap
    Way cool - I love it!
  8. ss34coupe
    ss34coupe
  9. sololobo
    sololobo
    Lookin good Ryno, classy old car. The Uniy body looks great with the red tint. Rock on bro, ~sololobo~
  10. JakeDW
    JakeDW
    from Missouri
    Lookin really nice.
  11. 60galaxieJJ
    60galaxieJJ
    Awesome build so far.
    YOUR TOW RIG IS BITCHIN!!!!!
  12. I've got a pair of front fenders and one rear fender for that car I might part with if you need them. I;m building a 31 model 54 5 window coupe and am not using the fenders.
  13. ryno
    ryno
    thanks for the offer,but at this point i think he is going fender less and we are channeling the body.
    he does have the fenders and running boards along with the brackets, as this car was complete when he purchased it, if you run across anyone that may need this stuff.
  14. porknbeaner
    porknbeaner
    Ryno,
    The chassis work in jam up friend. Real top notch.
    Looking at the pic with the body and the parking brake set on your uni-body the stud just dwarfs it. I know it is an illusion but it just makes your little ford look like a toy. ;)
  15. Lookig good. Gonna subscribe.
    Later,
    Dick
  16. This is a build that grabs my interest. My Stude coupe is a 31 also and plans for it are chop/channell/fenderless/wishbone suspension. Anxious to see more pics. Good luck
  17. Roger53
    Roger53
    Going to follow a long with every one . Lookin good your pickup is cool to ! Roger
  18. ryno
    ryno
    got a little further along with the rear suspension work,and added some more tubing.
    rear 2 link
    pan hard mounts,frame side.
    link side. i make a 2 piece insert. first section is welded to the coupler,a nd stuck inside of the box tubing, the outer plate is flush welded to the end of the tube. i plug weld from the sides in inner brace.
    rear x member / upper shock tower.
  19. chaddilac
    chaddilac
  20. niceguyede
    niceguyede
    from dallas
    Nice. More Please.
  21. ryno
    ryno
    thanks fellas!
    ill post some more pics next week. been busy.
  22. NickJT
    NickJT
    from S.E. PA
    Overkill is usually perfect!
    It's nice to see something different like this, making the old Studebaker into an awesome hot rod.
  23. ryno
    ryno
    thanks man.
  24. tooljunkie
    tooljunkie
    from manitoba
    definetly an eye for detail.from what i see so far the owner is in for a treat.
  25. You wouldn't have any photos of what the floor and substructure in that body looks like, would you? I just need an idea. Mine has none; I think it's the same body shell - it's a year newer, but a Rockne.
  26. Very cool Ryno!!
  27. ryno
    ryno
    thank you very much
    there was no floor in it or structure, when i got it, sorry.but i will be building some soon!
    thanks todd, we will be talking soon..
  28. subscribed!! nice work ryno!!!
  29. It certainly looks better than mine; will be looking forward to how you address the body wood and so forth.
  30. xderelict
    xderelict
    Watch out, that hot rod shit is contagious. :eek: :)
