Great progress on your build, I have 32 coupe on pallet rack in my warehouse stashed for project I most likely will never get to. Thought you might like to see my 32 PB roadster for some inspiration.--Kevin
Another long day today. I started the day finish sanding the drivers door completely. I then turned to cleaning up as much of the car as I could to be able to spray some surfacer to finish the day. I covered as much of the car as I got finished with 3 coats. Tomorrow I'll most likely continue the body work, with some block sanding of the surfacer also. What a day.....
Geeze your moving right along there Sam! I need to get into high gear and get my body prepped and ready for paint!
Another productive day yesterday. With all 4 wheels cleaned, I primed and painted them. I just couldn't body sand again. Besides, I want to get the tires mounted on them. I'm still unsure of the frame color. I originally wanted to paint it the same as the rest of the car. I am still leaning that way. [ Is that going to be too much???
Saturday, I took out the entire seat back and frame. The storage box attached will need some repair as well as some of the wood will need replaced. I cleaned out the car, to prepare it for primer and paint. Not much progress but I did manage to start cleaning up the grill shell. I put about 3 hours in it to finish the day.
Today, I finished the grill shell. After cleaning, and welding up a few broken areas, I gave it a coat of body icing since it is getting painted with the rest of the car. After much hand sanding I gave it a coat of primer. I then finished painting the bottom of the foot board pan so it could be placed permanently in the car. I had one wheel that had a run from painting so I sanded it off, scuffed the wheel and repainted ANOTHER RUN right back in it...... frustrating!!
I haven't posted for awhile but progress is slow but steady. I've spent a lot of time filling pits, and continuing bodywork. I've also started the process of cleaning the floor and applying POR paint. I've even started cleaning up the visor. This was a hard item to come by, and its a little rough, but it will look like new when finished. I don't think there are any easy parts to find for this car. My next Big hurdle is making the repairs to the grill. Any suggestions will be greatly appreciated. It's missing 2 bars, and several need straightening.
I finished the POR on the inner floor the other day. There hasn't been much progress since then, but today I managed to finish fabbing up a pair of axle blocks my son started on to lower the rearend 3 1/8 inches. After completing them I set the rearend to see if the ride heigth was going to be satisfactory. It works for me. I like it. Tomorrow it's back to sanding....
More progress today Finally!! Due to the previous owner not being able to find my trunk lid in 2 1/2 years I was forced into building my own. Today was the day for it. I roughed out the exterior shell. It's a reasonable first fit, but will need some work yet. Once I get it right, I'll build a wood frame to attach it to. For now I just wanted to see if I could do it. I'll go get some oak to build the frame tomorrow.
Thanks guys. My first effort on anything that large. I'll be glad to see the wood frame finished and final fit completed. Sent from my SM-S920L using The H.A.M.B. mobile app
Today I received a call from a fellow Hamber. It appears I am making a second trunk lid. So i thought I'd let you in on the process. First I cut the sheet metal to width allowing enough extra to brake 3/4" sides and a top edge. After that I measured the radius at the top of the sides and cut them into the deck lid. I then layout the edges every 2 inches all the way around the 3 sides.Almost halfway down the sides I made them every 1 inch. Using a shrinker/stretcher I shrunk the edges till they fit the cardboard patterns I made of the trunk area. If I happened to go a little tight I simply stretched the edge back out. I am not finished yet, but I'm within 6 inches of the bottom edge. Once I shrink up an inside brace for the bottom edge, the swell in the middle will disappear. This weekend I'll cut some oak and assemble a frame, then attach the deck lid and finish the lower edge and install the latch assembly. I also snagged this nice winged goddess on ebay for half what they normally go for on there.
I think I may have been the one who directed the guy to you. That is some superb work! Nice ornament, too. I have had a couple of those. I never want to let them go because they are so beautiful. Congrats on your find.
31Dodger,,,So you are the culprit. Lol He messaged me yesterday. I gave him my number. Happy to help him out. Sent from my SM-S920L using The H.A.M.B. mobile app
